V & H Sidewinder Megaphone *REPAIR*
- ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- zukdave
- Thank you received: 229
Sucks mines chrome so I guess rechrome or
for the money to do that just get a new one.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- 4TheKZ1000
- Visitor
- wireman
- Thank you received: 299
- Thank you received: 2829
- Kawboy74
- Thank you received: 52
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- Rickman
- Thank you received: 1
4TheKZ1000 wrote: I didn’t have a clamp at the megaphone and collector joint. It was a tight fit and had to use a rubber hammer to make connection, so I didn’t feel it was a problem. He said that when the pipe vibrated that the pipe is moving around and a clamp at this joint is a must.
What kind of clamp should this be? I sure didn't get one with mine.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- 4TheKZ1000
- Visitor
see Kerker clamp below.....
- zukdave
to use a clamp.
Like was said I had to beat mine apart when I
was making mine fit. I think if the joint was
loose enough to slip a little they wouldn't crack.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
