- Thank you received: 299
Kz900: Stock Bore - High Compression Pistons
- wireman
I check them at 180 myselfkawasaki mike wrote: Les I have a question for you as you seem very knowledgable on these kz's. Checking valve clearances is it better or more accurate to check the clearance 180 degrees opposite peak lobe hight or about 45 degrees after the valve comes back in its upward rotation? Some say check at opposite position from deepest position. What is your take on this. I am running 6 thousanths and 4 thousanths exhaust and intake. Figure it is better to hear them than smell them.
- NakedFun
- Thank you received: 99
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- kawasaki mike
- kawasaki mike
- Thank you received: 4
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- kawasaki mike
- kawasaki mike
- mtbspeedfreak
- Thank you received: 36
kawasaki mike wrote: I owe alot of that to Scott from S&K racing in Dayton, Ohio. He is anal about the right x patern in the cylinders,the right grit, the proper boring plate and the exact ring gaps. He even said taht 105 hp is the most I could possibly get with a perfect tune-up and everything perfect. So, I am pleased as hell. Thanks for your input.
Do you know what dyno you were running? 105 seems very good for a 1015!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- NakedFun
Cory
1976 Kawasaki KZ900
- Bozo
- Ride it like u stole it
- Thank you received: 105
How does your bike compare to some new hardware - just curious.
Sorry if this is off the topic guys.
- LarryC
Larry C.
- Bozo
That said if you use the same dyno for tuning you can monitor gains/ loses better.
- LarryC
Bozo wrote: I have to agree, since no dyno test is the same. As you might've noticed I wrote "didn't/ won't dyno mine" for that very reason, I prefer the seat of pants approach (drag your mate).
That and you can tune to make a dyno happy and loose ET & MPH at the drag strip. It's neat to have a number to look at but it's better when the number is reflective of something meaningful and comparable to the real world.
Larry C.
