Kz900: Stock Bore - High Compression Pistons
- NakedFun
06 Sep 2012 14:14
Hi,
Was wondering if anyone knew where I could find a stock bore, high compression piston? Are they available from somewhere? I know I can get an over-bore (1015) with higher compression. Any information for a supplier would be greatly appreciated.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- les holt
Re: Kz900: Stock Bore - High Compression Pistons
06 Sep 2012 17:12
I think I have a brand new set on the shelf at the other house, I'd have to check this weekend when we go but I'm pretty sure they are 903 (stock bore) 10.5-1 weisco's, still in the box.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- NakedFun
06 Sep 2012 19:00
Ooohhh. Let me know if you are interested in getting rid of them.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- les holt
06 Sep 2012 20:01
I will, knowing me I prolly bought them right cause it ain't something I would buy for myself so I'll make you a good deal on them.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- wireman
06 Sep 2012 20:02
A nice set of drop in cams and some 28s would work good to pump that 900 up with those pistons.
- NakedFun
07 Sep 2012 00:07
Considering it.... I am operating on the premise that the inspection of the bores I have done, show that they are within spec and probable just need a hone. Might as well just keep as much cylinder wall thickness as I can and get some squeeze. I checked Wiseco's site, they don't appear to offer a stock bore piston. Only the 1015 is the smallest bore for the 900. As far as the cams are concerned, I would simply like a set that are very streetable, and don't require grinding & clearancing the head. A couple of additional questions though:
1. Do I need to weld the crank with this combo?
2. Anything that should be done with the connecting rods?
3. When should bearing plate brace be used?
4. Trans gears back cut?
5. How much would the stock 26's be a restriction?
I am also considering getting the head ported by Larry C. I really don't know if I want to tie money up in the motor. I have two modern liter bikes that make crap loads of power. I may just want to leave this one podded, jetted, and exhaust. Was going to throw the high compression pistons to pull a little more out of it. This includes the new Dyna ignition and coils.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- wireman
07 Sep 2012 00:25
If youre going into the bottem end its never a bad idea to weld crank,new cam chain etc while youre in there.
As far as undercutting trans I wouldnt waste the money unless the dogs look beat up when you inspect them,throw the 26s under the bench and find some of those stock 28s off a 79-80 1000 itll really help for a low buck investment.
- Old Man Rock
07 Sep 2012 06:23
Here you go...
If over 1015cc on 900 engine case, upper case cylinder holes need enlarging for larger diameter cylinder sleeves.
Cylinder w/Piston Kits
#118 Grinds Pop & Go Cams
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- NakedFun
07 Sep 2012 10:42
From what I've read, a 1015cc can be done on a stock 900 sleeve/cylinder as it simply an overbore. If you go to the 1075cc, then you either need new sleeves or a later KZ1000 cylinder?
Wireman,
I got your PM, thanks.
Cory
Wireman,
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- NakedFun
07 Sep 2012 10:44wireman wrote: If youre going into the bottem end its never a bad idea to weld crank,new cam chain etc while youre in there.
I tried, but got screwed on Ebay! So I am still on the hunt for now. The VM26's I have, are in nice shape and I thought I would run them if it was only going to give up a couple of horses.
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- wireman
07 Sep 2012 10:56
Id say the 28s will give you as much if not more of a bump in power than those high compression pistons will
- wireman
07 Sep 2012 10:581015 pistons in stock 900 sleeves will leave you with really thin sleeves making it hard to keep a round bore,especially when the motor heats up.NakedFun wrote: From what I've read, a 1015cc can be done on a stock 900 sleeve/cylinder as it simply an overbore. If you go to the 1075cc, then you either need new sleeves or a later KZ1000 cylinder?
Wireman,
Cory
youll give up a lot of power if the rings cant seat when cylinder distorts
