- Thank you received: 99
Kz900: Stock Bore - High Compression Pistons
- NakedFun
Was wondering if anyone knew where I could find a stock bore, high compression piston? Are they available from somewhere? I know I can get an over-bore (1015) with higher compression. Any information for a supplier would be greatly appreciated.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- les holt
- Thank you received: 288
Les
- NakedFun
Cory
1976 Kawasaki KZ900
- les holt
Les
- wireman
- Thank you received: 299
- NakedFun
1. Do I need to weld the crank with this combo?
2. Anything that should be done with the connecting rods?
3. When should bearing plate brace be used?
4. Trans gears back cut?
5. How much would the stock 26's be a restriction?
I am also considering getting the head ported by Larry C. I really don't know if I want to tie money up in the motor. I have two modern liter bikes that make crap loads of power. I may just want to leave this one podded, jetted, and exhaust. Was going to throw the high compression pistons to pull a little more out of it. This includes the new Dyna ignition and coils.
Cory
1976 Kawasaki KZ900
- wireman
As far as undercutting trans I wouldnt waste the money unless the dogs look beat up when you inspect them,throw the 26s under the bench and find some of those stock 28s off a 79-80 1000 itll really help for a low buck investment.
- Old Man Rock
- Thank you received: 225
If over 1015cc on 900 engine case, upper case cylinder holes need enlarging for larger diameter cylinder sleeves.
Cylinder w/Piston Kits
#118 Grinds Pop & Go Cams
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- NakedFun
Wireman,
I got your PM, thanks.
Cory
1976 Kawasaki KZ900
- NakedFun
wireman wrote: If youre going into the bottem end its never a bad idea to weld crank,new cam chain etc while youre in there.
I tried, but got screwed on Ebay! So I am still on the hunt for now. The VM26's I have, are in nice shape and I thought I would run them if it was only going to give up a couple of horses.
Cory
1976 Kawasaki KZ900
- wireman
- wireman
1015 pistons in stock 900 sleeves will leave you with really thin sleeves making it hard to keep a round bore,especially when the motor heats up.NakedFun wrote: From what I've read, a 1015cc can be done on a stock 900 sleeve/cylinder as it simply an overbore. If you go to the 1075cc, then you either need new sleeves or a later KZ1000 cylinder?
Wireman,
Cory
youll give up a lot of power if the rings cant seat when cylinder distorts
