Salvage Yard Engine
- slaughridge
'83 KZ1100d2
'80 KZ1000e2
'74 KH500
'71 CL350
- MFolks
- Thank you received: 540
Kinda depends if the engine is seized or not, if it is seized, some ATF down the sparkplug holes might get it loose.
- slaughridge
'83 KZ1100d2
'80 KZ1000e2
'74 KH500
'71 CL350
- MFolks
Was the engine over reved? Use the cheapest gas available? Wrong sparkplug heat range? Black sparkplugs may have coated the cylinders with carbon, but if running lean, there's the chance of overheating, possible burning valves & melting pistons.
- bountyhunter
- Thank you received: 337
- slaughridge
'83 KZ1100d2
'80 KZ1000e2
'74 KH500
'71 CL350
- roy-b-boy-b
- Thank you received: 103
- slaughridge
'83 KZ1100d2
'80 KZ1000e2
'74 KH500
'71 CL350
- OldSchoolZ
Go from there. 900 seems a bit high, since I can find a GSXR1000 engine with lower miles for the same price.
Remember, don't work on your bike so much you never ride it.
- bountyhunter
That would be too risky for me to buy a giant question mark, but i would if the guy would let me do some tests and give me some kind of warranty in case of gross damage that makes it unusable.slaughridge wrote: ok, all good tips, but is 900 bucks a decent price for a good used engine if everything checks out?
- mtbspeedfreak
- Thank you received: 36
Just my $0.02
2000 ZRX 1100
1976 KZ 900- Daily Driver
- Thank you received: 2829
kzrider.com/forum/23-for-sale/544731-1977-kz650c-1#544731
