- Thank you received: 2
KZ1000 Cam chain tensioner Fix??
- vintagebiker
If all else fails, JUMP!
- vintagebiker
- pete greek1
- Thank you received: 185
Pete
- LarryC
vintagebiker wrote: I think I have other issues here. I'm going to pull the valve cover off and look for oil. There is too much top end rattle still. I tripple checked the valve clearances and it can't be that. Maybe low oil pressure to head. Oil light goes off after bike is running, almost imediatley. Like I said I never heard this bike run and it hasn't run in at least 5 years.
Check the top idler sprocket bearing. See if you can wiggle the sprocket up/down. They're common fail items on old KZ motors.
Larry C.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
pete greek1 wrote: Wow, Bike looks great, hope you get it to run as good as it looks.
Pete
Yup, what he said.
Sounds like you have something out of kilter with the tensioners, or like Larry said the top roller bearing is failing on you. Hope you get that ironed out before something major happens.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- vintagebiker
I think the valves were just kissing the pistons. No marks on them or the valves. I ran the bike for about 5 minutes like that. thats what all the rattling was.
Can't wait to fire her up tomorrow now.
- dragtostreet
1973-1978 Install the cam chain tensioner assembly on the cylinder block. Torque the mounting bolts to 14.5 ft. lb.(1.0 mkg). Loosen the locknut and the bolt on the left side of the camshaft chain tensioner body, located on rear of cylinder block.
NOTE: A spring inside the tensioner will take up the slack in the camshaft chain.
It never says to retighten the bolt after the slack is takin up. Is this the right way or is there another way I am lost ran it both ways and neither way makes anymore noise then the other.
- vintagebiker
- Thank you received: 797
- BlackZ1R
vintagebiker wrote: I can't believe i had the cam timing off. And the bike still ran. thank god I didn't bend a valve.
Glad you found it. So how far off was it? was it intake or exhaust or both?
Kawasaki
- BlackZ1R
531blackbanshee wrote: on my 80 model z1r the automatic adjuster use the "set bolt" to hold it back for installation only.after that it sets down in a notch so that the spring pushes it out and the lock rings and bearings prevent it from backing off.
Leon, that isn't a particularly good design, as they will slip. Ask me how I know this. :pinch: I usually pick up an earlier version to replace the '79 or '80 model "automatic" chain adjusters.
YMMV
Kawasaki
- vintagebiker
