- Thank you received: 2
KZ1000 Cam chain tensioner Fix??
- vintagebiker
Attachment drillingtensioner.jpg not found
Attachment tensioner.jpg not found
Attachment tensioner2.jpg not found
If all else fails, JUMP!
- Thank you received: 2829
The modification you made should work fine, but you will need to loosen the pinch screw for the rod to move in. When turning in the screw you added be careful not to apply too much tension as that can cause problems. Ed
- vintagebiker
It seems to work OK and it is just snug enough to stop the ratteling.
- 4TheKZ1000
- Visitor
- LarryC
Larry C.
- DFIGPZ
- Thank you received: 122
- dragtostreet
- 4TheKZ1000
- Visitor
- dragtostreet
- LarryC
dragtostreet wrote: I thought that the tensioner lock bolt was supposed to be loose so that the rod can move except when taking the tensioner off the engine, so that it doesn't come apart.
No. You want the plunger locked into the position that keeps the correct tension on the chain. It's when the bold backs off that the noises start happening.
Larry C.
- vintagebiker
What is the difference in the MCII chan? I see the sprokets are different. But is the length different?
- vintagebiker
Attachment finalkzpics001.JPG not found
Attachment finalkzpics002.JPG not found
Attachment finalkzpics003.JPG not found
Attachment finalkzpics004.JPG not found
Attachment finalkzpics005.JPG not found
