- Thank you received: 15
Cam lobe base circle varies in clearance.
- 893cv
www.tildentechnologies.com/Cams/CamBasics.html
1980 kz1000 LTD
1978 Z1R
- faffi
- Thank you received: 36
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- Motor Head
- Thank you received: 391
893cv wrote: Here is some information. The tight areas are not on the base circle. Those areas care either the opening or closing ramps. Stock Kawasaki cams have very long opening and closing ramps.
At TDC Compression stroke, those ramps won't be anywhere near the Lifter/ cam follower. You should be able to rotate the crankshaft 45 degrees and not hit a "Ramp".
- Thank you received: 2829
- wireman
- Thank you received: 299
- 893cv
Yes, if you read the OP's original posting he states that at TDC and then with the lobe pointing directly away from the valve, he measured .1 mm clearance. Good, he is measuring the clearance between the shim and the true base circle of the cam. He then states " When I rotate the cam a touch more it gets tighter than .05mm." again, true. I bet if he keeps rotating the cam a touch the clearance will disappear, and if he keeps rotating just a little bit more the valve will begin to OPEN.
That sure sounds like an opening ramp to me.
1980 kz1000 LTD
1978 Z1R
- bobski911
Thanks everyone. And thanks 893cv for the cam basics. I'm assuming I didn't have the right terminology to explain where my issue is. Or maybe like Wireman said "some people think too much".
So, here is a pic of what I'm trying to explain. Just to make sure everyone knows what I'm talking about. :lol:
Attachment camshaftlobe_diagram.jpg not found
- RonKZ650
- Thank you received: 240
This was my question also way back in 1978. I was lucky enough to be friends and go to the same high school as Keith Pestotnik "the motorcycle man", who worked for Kawasaki and was a factory mechanic. He told me the way he did it, and that was to determine what valve clearance you are looking to get. Lets go with .10mm just as example. The way you would do it would be get a .10mm feeler and try to insert it while slowly turning over the engine with your 17mm socket on the crank. If anywhere in the rotation of the cam a .10mm fits then try a .15mm. If .10 fits and .15 doesn't you are OK on that valve and repeat on the next. He said most engines were set too loose going by the book procedure. Of course 1 size too loose is probably all we are talking about though.
- Thank you received: 2098
- bobski911
RonKZ650 wrote: determine what valve clearance you are looking to get. Lets go with .10mm just as example. The way you would do it would be get a .10mm feeler and try to insert it while slowly turning over the engine with your 17mm socket on the crank. If anywhere in the rotation of the cam a .10mm fits then try a .15mm. If .10 fits and .15 doesn't you are OK on that valve and repeat on the next. He said most engines were set too loose going by the book procedure. Of course 1 size too loose is probably all we are talking about though.
Thanks Ron,
Do you have a recommendation for a clearance that I should go for? For example, if I set the tight area to .10mm clearance, that would mean the rest of the base circle would be sitting around .15-.17mm.
Thanks again everyone
- 893cv
1980 kz1000 LTD
1978 Z1R
- mark1122
- Keep twisting it
- Thank you received: 109
Some may not realize that this tight spot can be in a dif spot around the base circle,on each lobe. so if u just use the factory procedure , u would never know that u had a tight spot.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
