Cam lobe base circle varies in clearance.
- bobski911
Where should I take my measurement from? TDC? cam lobe pointing directly away? or at the tightest point on the cam lobe?
I took a measurement at TDC and pointing directly away and got .10mm. When I rotate the cam a touch more it gets tighter than .05mm.
If I take my measurement from the tightest point on the cam base circle, what should I set the clearance for?
One person 3 years ago on this site said the lobes are not perfect and kawasaki told him years ago to point the cam directly away from the buckets and aim for the max clearance. Another person told me measure from the tightest point on the lobe and aim for the tightest clearance.
I want to get this right once and for all. I'm sick of taking the cams off :blink:
Thanks
- wireman
- Thank you received: 299
- bobski911
Thanks
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- wireman
I set the exhuast closer to the middle since they get hot/expand a lot more than intakes do.
- bobski911
wireman wrote: I set the exhuast closer to the middle since they get hot/expand a lot more than intakes do.
What do you mean you set it closer to the middle?
Thanks
- wireman
- Godfrey
- Thank you received: 10
1981 650CSR frame
1980 KZ750E engine
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bobski911
mark1122 wrote: i have run into this as well. my thoughts are that if the clearance is toooo tight the valve wont close. so i use the tight spot, and shim to that.
Thanks guys,
Mark, what kind of clearance would you shim at the tight spot?
- RonKZ650
- Thank you received: 240
- mark1122
- Keep twisting it
RonKZ650 wrote: Set your clearance to recommended spec at the tightest point, so most guys would run .10-.15mm at that point.
X2
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
