**FIXED** 1981 Kz750E wont start after an accident
19 Jul 2012 01:11 #536969 by Koki
Replied by Koki on topic 1981 Kz750E wont start after an accident
Scratch that, it was a stupid question.
NEW QUESTION!
Alright, so I got some progress on the bike, but still won't start. What's going on is that I'll hold the starter button and it simply cranks and the exhausts putts air out, but when I hold the starter button and turn the throttle about 1/3 the way, occasional bursts of air will shoot out of the air filter(under the seat) and I'll hear air pop around the engine as well(occasional as well).
Sorry for being such a pain in the ass, I really appreciate your help though.
Thanks,
Koki
1981 Kz750E
  • Motor Head
19 Jul 2012 01:17 #536972 by Motor Head
Replied by Motor Head on topic 1981 Kz750E wont start after an accident
Choke on, No Throttle to start the motor cold.
19 Jul 2012 01:18 #536973 by Koki
I also tried that, no luck either:\
1981 Kz750E
  • Motor Head
19 Jul 2012 01:20 #536974 by Motor Head
Like I posted earlier, have you checked compression?
19 Jul 2012 01:23 #536975 by Koki
Ah, that I haven't. Partially because I don't have a proper gauge and partially because I'm hoping that's not the problem haha. I'll see if I can get my hands on one sometime soon.
1981 Kz750E
19 Jul 2012 01:28 #536977 by Patton
Replied by Patton on topic 1981 Kz750E wont start after an accident
Insufficient clearance on intake valve can cause backfiring through the carb.
Good Fortune! :)
  • Motor Head
19 Jul 2012 01:40 #536980 by Motor Head
As Patton said, valve clearance. Or maybe cam timing out of phase. You do have the service manual for your bike, right? It will explain the compression test, the valve clearances, and the cam timing.
30 Oct 2012 14:52 #556397 by AeroSFCity
Replied by AeroSFCity on topic 1981 Kz750E wont start after an accident
Had this happen to my 81 750e. Backfiring out carbs and no start but would crank. Drop bike on right side during accident in sfcity. Thee timing side crankshaft bolt was bent.
You definitely have something wrong with you timing advancer area.
1980 KZ750E
30 Oct 2012 19:15 #556435 by riturbo
Replied by riturbo on topic 1981 Kz750E wont start after an accident
My son skidded my 550 down the road. Was backfiring like that. Turned out that there was a cut wire where the harness went in the front just in front of the gas tank.When he went down it pinched it
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
