**FIXED** 1981 Kz750E wont start after an accident
- Koki
I've replaced all the spark plugs, replaced the main fuse, replaced the oil filter, and cleaned the battery connections but haven't gotten any results. Also, I've checked the solenoid by bypassing it, but it doesn't turn like that, so the solenoid should be fine.
Any ideas on what it may be?
Thanks,
Koki
**FIXED**
Turns out I'm blind. My alternator was bent to hell, so I replaced that and got my baby back up and running. Nevertheless, I learned a ton from you guys and tinkering around on my own.
Thank you!
1981 Kz750E
- osage
- Thank you received: 4
Damage to ignition cover, right hand controls or safety interlock switches?
1976 KZ750B1
1982 KZ750H3
- Koki
I'll check all of the switches in a moment, thanks for the advice.
1981 Kz750E
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bountyhunter
- Thank you received: 337
Guess what idiot did that after a car knocked me down....
- Thank you received: 2098
- Koki
bountyhunter wrote: make sure one of the kill switches didn't accidentally get bumped on.
Is there more than one kill switch? And where would it be?
Thanks for all the advice guys, I'll check it out today.
1981 Kz750E
- Koki
So I took some starter fluid and sprayed it into my air filter to see if the pump was the problem, but the bike just turns over and wont catch. After spraying the fluid and trying to start the bike, there are occasional "putts" but nothing substantial. Is that a sign for another problem?
1981 Kz750E
- baldy110
- Thank you received: 512
- bountyhunter
- Godfrey
- Thank you received: 10
1981 650CSR frame
1980 KZ750E engine
If no spark, what is voltage being actually received ay the coil primary terminal when the ignition switch is ON?
Answers to these questions will aid in diagnosing the cause for failure of combustion.
The cause is usually related to either or some combination of:
Compression;
Spark (or spark timing);
Fuel mixture (gasoline supply and air/fuel ratio).
