- Thank you received: 4
Engine rebuild?
- KZ1000inaus
- Luminous Red KZ1000 A2
I've done the tea spoon of oil in the barrel test and it came back with 130 psi so looks like I have blown rings.
Any suggestions where to go from here? As in what to expect to replace? Pistons, rings etc.
Is there anything to upgrade or replace while I have it apart?
Is it likely to need rebore
What make of parts do u recommend?
I'll start to take it apart tomorrow to see the extent of the problem
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- faffi
- Thank you received: 36
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- KZ1000inaus
faffi wrote: Have the engine sat for a long period, or has it been used regularly lately? It is not unusual for piston rings to get stuck when unused for long periods, but letting it soak for a few days in diesel often frees the rings. You can add the fluid from the spark plug hole at TDC. The small amount shouldn't ruin the engine oil even if all runs past the rings.
ahhh that could be it. I have done a few miles on it since i got it but it was imported from US to Aus late last year and i bought it early this year. The speedo showed 12500 miles and the excellent condition of the bike made me believe it was, which i still do. but that did make me wonder why i was getting such a serious engine problem from a renowned tough engine so early.
The whole bike looked like it was a shed find and covered in a few years of storage dirt and protective oil stuff, and the engine oil and brake fluids had seen better days.
I'm half looking forward to taking it apart as i will know more about the bike i intend never to sell
- faffi
I'm positive I'd find lots inside my engine that's not factory fresh. But it works just fine and doesn't use oil. Until it really asks for attention, my engine will stay together. And when attention is needed, I'll pop in the spare engine without opening it, either
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- KZ1000inaus
Oh i'm definitely with you on that one, but no2 cylinder was not firing and since ive had the bike it's never run properly..faffi wrote: It's your bike Personally, I'm a "if it ain't broken, don't fix it" person. Others live by the "if it ain't broken, rip it apart and find out why" token
- Motor Head
- Thank you received: 391
KZ1000inaus wrote: After completing a compression test cylinder 2 came back with a reading of about 40 psi.
I'd do a valve clearance check, and if tight, back of the camshaft bearing caps to get clearance. Then by hand, rotate the motor through both a dry and wet Leak Down Test. Rotate by the 17mm nut at the right engine ignition cover, not the 13mm one. In the direction of normal travel of course. You will have to hold down with a bit of tension on the cam chain, between the cams. When re-installing valve cover, be sure to take the Wedge out of the automatic cam chain tensioner. Thats under the cap, 17mm wrench/ spanner, under the carbs.
- KZ1000inaus
I checked the valve clearances last night and if my memory serves me right No.2 was one of the better ones with a clearance of .08. where as No.4's exhaust was .23 ! which was the highest.Motor Head wrote:
that begs another question. what is the correct clearance? as my manual says one thing (.15mm) and i think a thread in the forum says .05 to .10.
I think i'll get a guy around to do a leak down test as well
- Motor Head
Did you recheck compression, or restart the motor to see if there was any difference, after the adjustment?
- Denvgasm
- KZ1000inaus
it's a 1978 KZ 1000A2 - No. KZT00AE - 073210Denvgasm wrote: What model engine?
- KZ1000inaus
Ive not adjusted the clearance as it's my first time on checking/adjusting them and i'm picking up the tool/shims today.Motor Head wrote: The .1mm sounds better.
will it really make that much difference to a cylinder that runs at 40PSI normally and then 120-30 if oil is put in cylinder and a compression test run?
sorry but i'm a bit of a noobie (which i'm trying to rectify) when it comes to this much detail.
