- Thank you received: 3
79 KZ1000 shafty, clickity click in transmission.
- kzspartan
15 Jul 2012 11:49 - 15 Jul 2012 11:50 #536057
by kzspartan
Replied by kzspartan on topic 79 KZ1000 shafty, clickity click in transmission.
I am having a similar sound coming from my 1980 kz1000 ST. I can not determine if it is the neutral balls or the output shaft bearings?
Do the Nuetral BB spin in the case?
Last edit: 15 Jul 2012 11:50 by kzspartan.
- loudhvx
- Thank you received: 1616
15 Jul 2012 15:53 #536106
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 79 KZ1000 shafty, clickity click in transmission.
For us, it was neither. It was the nut rotating loose in the housing with a bit of the output shaft in it.
I doubt the neutral finder BB's will make that much noise that you would hear them.
1981 KZ550 D1 gpz.
Other links.
- kzspartan
15 Jul 2012 22:20 #536205
by kzspartan
Thanks for the reply, I will post some vids on the sound.
