- Thank you received: 1616
79 KZ1000 shafty, clickity click in transmission.
- loudhvx
EDIT: It's a 1979 KZ1000 E1 shaft.loudhvx wrote: ... My buddy just got his 81 ST (or was it 80?) on the road last week. We are still tinkering with a lot of details, tuning carbs etc.
Incidently, we've been puzzled by a strange sound in the trans. With the bike on the centerstand, when we rotate the rear wheel, there is a clicking sound in the trans. It's pretty quiet, but definitely there. The sound doesn't sound bad like anything broken, just strange. I was wondering if you had the same sound.
I've never heard it on any chain drive KZ's.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- loudhvx
531blackbanshee wrote: lou,
i don't know about shaft drives,but i have seen the output shaft bearing break around the circumference and pop the cage off the bearing.then the balls clickity clack on each other ass they roll over the top of the race and fall down the other side.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
Uh oh. That looks like what the sound sounds like. At first I was thinking the sound was something to do with the neutral finder because it does sound like little ball bearings falling into place.
We'll have to see if we can yank the right-angle drive.
Thanks Leon.
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 797
on my 80 z1r when i was doing my swingarm conversion i first heard it while sitting down by the left side of the engine and mindlessly spinning the outputshaft with my fingers.you could go slow and hear the balls drop over the top one at a time.
also when i would throttle it hard leaving a stop light it would kinda pop and jerk around,enough to make you quit what you were doing for fear of blowing"something" apart.
you have to split the cases to change it.
that is the biggest sucky part,otherwise pretty straight forward.
i got the bearing from ape.
- loudhvx
I wonder if the shaft drive setup is different.
Notice bearing #22 rides on the bevel drive shaft which connects to the output shaft of the trans. I wonder if it's that one, or is it #33 on the trans fiche? I think that is the one you are describing.
1981 KZ550 D1 gpz.
Other links.
i am describing #33 the one with the circlip groove machined in it.
they crack through the groove and out the side which pops the cage off which lets the balls start touching each other because the cage is no longer separating them.
- loudhvx
photo by H Fajardo.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
In search of trans output shaft 13128-1019. Found on 79 E1 and 80 E2.
1981 KZ550 D1 gpz.
Other links.
- VirginiaKZ
Edit: Bummer, just read your last post. At least you know what is needed.
1980 KZ1000 ST
that sucks,first time i have heard of this failure.
- Motor Head
- Thank you received: 391
- loudhvx
Leon, yeah, it's a head scratcher. Unfortunately, when you get a new used bike, there will often be goofy mysteries like this. I'm not even sure what to look for as a cause. Maybe something will show up when splitting the cases.
Thanks, Motorhead. We've been watching that NOS shaft on ebay, but I think he has a line on a used trans for much cheaper. But you never know with used stuff.
1981 KZ550 D1 gpz.
Other links.
