- Thank you received: 245
Oil leaking at the cam cover - KZ1000
- Kidkawie
- I bleed premix
Whats it made of, yellow pine? lol
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- jonnybravo
- Banned
- Thank you received: 18
hahahahhaKidkawie wrote: Humidity warps heads?
seriously its the mating surfaces, sand em with a 3/4 by 3/4 square stock, (approx 5 inches long) of wood with 100 to 150 grit, u will see when the surfaces are even, trust me, prep the gasket with gaskacintch and ur good, gotta watch those pesky cam cap areas though,
- djw
- kawasaki mike
- kawasaki mike
- Thank you received: 4
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- wireman
- Thank you received: 299
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:Kidkawie wrote: Humidity warps heads?
- Kapahulu
This oil leak is bugging the heck out of me. I've got all these bikes I work on and just this one KZ1000 has this persistent oil leak. It should be a simple fix but it hasn't been so far.
In the last couple of weeks I bought a 1982 GPZ550 and a 1976 KH400. The KH400 is amazing, it's almost in brand new condition, with less than 200 miles on it. I bought it in Alaska and it's going to sit there in storage for another year until I go back and put it in a crate for shipping to Hawaii.
The GPZ I bought for a friend and he decided he doesn't want it. I'm just going to fix it up and sell it, maybe make a few bucks.
2strokeworld.com
- Motor Head
- Thank you received: 391
You can do a Low Pressure Check, Using a Regulated Air Supply at 4psi. Connect to the crankcase breather nipple, and spray some soapy water over the area. If there is a crack/ pin hole etc in the cover/ head it will show you with bubbles.
- Kapahulu
When the cam cover was off I checked the head with a straight edge and it appeared to be flat.
Still to try:
- Low pressure check mentioned by Motor Head. I checked the breather to make sure it wasn't clogged.
- Check the torque on the head bolts (not cam cover, but the head).
- Cam cover - since I have tried using two covers with the same result, I don't think it's cracked, I could be wrong, can look at them a little more thoroughly.
- Sanding the mating surface on the head, mentioned by Johnny Bravo - I think I would have to take the head off to make sure the metal particles get cleaned out before I run the motor after doing it. Might be saved as the last resort.
2strokeworld.com
- Motor Head
- Kapahulu
What I see is seepage over the top part of the cam cover gasket. Maybe I should try that other cam cover again.
Thanks for the support, I hope to get this taken care of once and for all.
2strokeworld.com
- Motor Head
- Thank you received: 2098
With the mating surfaces on both cover and head clean and dry and free of any old gasket remnant (basically in as-new condition) and the new gasket installed dry, should operate leak-free in the gasket area.
(I use the gasket available at Z1 Enterprises.)
