Oil leaking at the cam cover - KZ1000
- Kapahulu
13 Jun 2012 23:52 - 13 Jun 2012 23:54 #529001
by Kapahulu
2strokeworld.com
Oil leaking at the cam cover - KZ1000 was created by Kapahulu
My '78 KZ1000 runs so nicely - I hope I can get this cam cover leak fixed soon! First I replaced the cam caps and was still having oil leak issues. Then I thought maybe the leaks were because the cam cover was chromed and the smooth surface made it harder to get a good seal. Some suggested that might be the cause and that if the sealing surface were roughed up that might fix it.
Instead, I decided to take a regular (unchromed) cover off a spare KZ1000 motor. There were no oil leaks on that one.
Now I've got that unchromed cover on the bike, new gasket and oil is definitely leaking from above the gasket. I have the cover bolts evenly torqued.
So I'm thinking of two possible solutions. One is to seal the top of the cover to the gasket with Permatex Ultra Black. The other idea is to use two cam cover gaskets. I don't have an extra on hand and will have to order it.
Thoughts?
Thoughts?
2strokeworld.com
Last edit: 13 Jun 2012 23:54 by Kapahulu.
- cpg
13 Jun 2012 23:58 #529004
by cpg
Current Bikes: KZ440 LTD and KZ305 CSR
Replied by cpg on topic Oil leaking at the cam cover - KZ1000
I just put mine back on and put ultra grey around all the rubber mating surface of the cam plugs and it sealed really nice.
- 4TheKZ1000
- Visitor
14 Jun 2012 00:18 #529007
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Oil leaking at the cam cover - KZ1000
is it an emission control head. if it is you might have used the wrong gasket?
- Kapahulu
14 Jun 2012 04:15 #529032
by Kapahulu
2strokeworld.com
Replied by Kapahulu on topic Oil leaking at the cam cover - KZ1000
No it's a '78 head and the gasket is correct.
2strokeworld.com
- Kapahulu
16 Jun 2012 17:53 - 16 Jun 2012 17:54 #529637
by Kapahulu
2strokeworld.com
I tried sealing up the existing gasket (which is pretty new) up with Permatex Ultra Black above and below the gasket. Didn't work, still leaking.
Now I'm out of valve cover gaskets until my order comes in from Z1 Enterprises. In the meantime, maybe I'll remove the gasket completely and try forming one with the Permatex.
2strokeworld.com
Last edit: 16 Jun 2012 17:54 by Kapahulu.
- DoubleDub
- Visitor
16 Jun 2012 20:45 #529691
by DoubleDub
Replied by DoubleDub on topic Oil leaking at the cam cover - KZ1000
Where is the leak? Is it possible that it's coming from the tach cable area? That's a common leak.
- Kapahulu
16 Jun 2012 21:45 #529697
by Kapahulu
2strokeworld.com
It's the cam cover, not the tach cable area. Funny because I changed cam covers and am using one from an engine that did not have leaks. And I'm using a brand new gasket.
2strokeworld.com
- Atraeu
17 Jun 2012 00:51 #529738
by Atraeu
It is time to order more signatures please contact Jimbo at Metro signatures and fortunes llc.
250 Ltd
Custom 1100
Replied by Atraeu on topic Oil leaking at the cam cover - KZ1000
If still leaking after new gasket and previously non leaking cover I would look at the mating surface for damage
250 Ltd
Custom 1100
- wireman
- Thank you received: 299
17 Jun 2012 01:26 - 17 Jun 2012 01:28 #529756
by wireman
Both sides of gasket,let it get tacky before installing ,that gasket maker in a tube could end up someplace you dont want it
Replied by wireman on topic Oil leaking at the cam cover - KZ1000
Attachment PERMATEX20SPRAY20COPPER20COAT.jpg not found
Last edit: 17 Jun 2012 01:28 by wireman.
- Kapahulu
17 Jun 2012 14:23 - 17 Jun 2012 14:25 #529873
by Kapahulu
2strokeworld.com
The mating surface (top of the head) looks fine. After removing the gasket and cleaning the surfaces, I put the cam cover on and noted some areas where the two surfaces have more space between them in some spots. And they seem to be the same places where the oil is leaking out.
Yesterday I cleaned both surfaces, put Permatex Ultra Black all around and put the cover on with the bolts finger tight. Tonight I'll tighten up the bolts and then try it out.
Wireman, next time I take the cover off and when I have a cam cover gasket, I'll go with your recommendation. If the Permatex Ultra Black works I won't be taking this cover off for a long time.
2strokeworld.com
Last edit: 17 Jun 2012 14:25 by Kapahulu.
- Kapahulu
18 Jun 2012 05:07 #530049
by Kapahulu
2strokeworld.com
Replied by Kapahulu on topic Failure
The Permatex Ultra Black was a terrible failure without a gasket. Don't bother trying it!
I checked USPS, the new gaskets should be here tomorrow.
2strokeworld.com
- wireman
18 Jun 2012 08:42 #530064
by wireman
Replied by wireman on topic Failure
When you tighten the valve cover bolts start in the center and work your way out to both sides to avoid warping the center
