- Thank you received: 47
Oil leaking at the cam cover - KZ1000
- BlackZ1R
- Kawasaki in my blood
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Kapahulu
I'm thinking about taking the cover to a shop for resurfacing. This bike runs real nice but the oil leaks are a pain and take a lot of time to fix.
My new gaskets arrived in the mail yesterday.
2strokeworld.com
- Kapahulu
So I went home and cleaned up the head thoroughly and cleaned the sealing surface with acetone. Then I put Permatex around the cam caps ONLY and then used double cam cover gaskets. Still there's some leaking happening. There's a little seepage at the left side of the exhaust cam and in the area of the two left cam caps, even though I had recently removed them, cleaned with acetone and let them sit in place overnight with Permatex.
I will retorque the bolts and see if that makes any difference.
2strokeworld.com
- Kidkawie
- I bleed premix
- Thank you received: 245
DoubleDub wrote: Where is the leak? Is it possible that it's coming from the tach cable area? That's a common leak.
+1
A leaking tach drive will cover the front of your engine.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Kapahulu
BTW Wireman, the guy at the machine shop said to install the gaskets (2 gaskets stacked) dry first before using any kind of sealant. So I followed his instructions except that I put sealant above the cam caps because that area seems to be a given for leaking.
Anyways, since there is still some seepage I bought a can of the copper spray a gasket.
It looks like the leak is between the cover and the gasket. So I'll spray the top side of the gasket. I don't think there are any leaks between the two gaskets.
2strokeworld.com
- bluezbike
- Thank you received: 104
I would also double check all your head bolt torque settings by loosening and then re-tightening them in the order suggested in the manual.
Bluezbike
79 KZ 1000 LTD
- 4TheKZ1000
- Visitor
good luck
- Kapahulu
I took the tank off and looked at the cover again the other day. With two gaskets there seems to be more loosening up on the torque. I retorqued the bolts and haven't had a chance to ride it since. I always torque in a star pattern from the center outwards.bluezbike wrote: I think after all that you have tried, it may well be that the mating surface on the head is worth another look as suggested by the mechanic. It doesn't matter if the engine is running well, that has nothing to do with whether the top mating surface is perfectly flat. Take a good straight-edge and check every surface you can along that top edge. Good luck.
Bluezbike
With all the hot weather in the U.S. mainland, surprisingly it's been pretty cool here in Honolulu, with temperatures in the high 70's and low 80's with almost daily rain.
I avoid riding in the rain and haven't checked for leaks again since I retorqued the cam cover.
I was figuring if the top of the head is warped, it would be from heat and then the head gasket might leak. That's why I was saying the engine runs great etc. But I guess there are other ways the top of the head could get warped. I wonder - if it is warped, can it be machined flat again? Seems like not.
I'll report back soon.
2strokeworld.com
- 4TheKZ1000
- Visitor
- jonnybravo
- Banned
- Thank you received: 18
- bluezbike
I notice you checked the torque on your cam cover but did you also check the torque settings on your head bolts, it may be that one or two were overtightened and warped (maybe temporarily) the head. I should have guessed you were from Hawaii from the name (I am Greek) and I have heard that sometimes excessive humidity warps the heads over time. Also check the head top surfaces with a good straightedge for true, it might show you if there is a dip or divot that as 4theKZ suggested might be filled with a weld or even weld-on and then finished flat. Machining the top of the head seems like it would be a bad idea what with the cam caps in the way but it may work, there are a few top machinists on this site who might know, I do not.
Good luck Kapa,
Bluezbike
79 KZ 1000 LTD
- Kapahulu
Kapahulu is a neighborhood in Honolulu. I am a realtor and use different neighborhood names on the various forums I am a member of. I'm mainly into KZ's but also have an RZ350. And I also had a CB550F, a GS550, a Zephyr 550 and a GPZ 550 in recent years. My real name is Mike.
2strokeworld.com
