crankshaft replacement
Re: crankshaft replacement
11 Jun 2012 18:01
#528225
turboguzzi wrote: ...feed some rope into the cylinder thorough the valve hole....
That's gonna be harder than depressing the spring retainer with two fingers. :woohoo: :laugh: :laugh:
Good Fortune! :)
11 Jun 2012 18:15
#528231
I've never done it on my bike, but on my old Chevy truck with a 350 V8 I used an air compressor and adapter to charge the cylinder with air (gotta make sure both valves are closed) to hold the valves in place while replacing seals. Anyone done this on a KZ? Ed
  • testarossa
  • testarossa's Avatar
11 Jun 2012 18:36
#528246
I have done the rope trick before to change the valve stem seals without removing the head. It did the trick on an old inline six Ford.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • z1kzonly
  • z1kzonly's Avatar
11 Jun 2012 18:42
#528250
Take the time to do it right.
Just think of this horror story. You start, do a couple of them.
Then all of the sudden your homemade jig slips and takes a 1/4" of your finger tip off clean
holy freakin ouch :blink: :ohmy:
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
11 Jun 2012 18:45 - 11 Jun 2012 18:46
#528253
the tool you need is called a valve spring sphincter. :woohoo:
Last edit: 11 Jun 2012 18:46 by 4TheKZ1000. Reason: spell
  • nads.com
  • nads.com's Avatar Topic Author
12 Jun 2012 00:19
#528377
I already figured in the springs might be hard to compress situation.
And the answer is: a longer bar! Looks like it will fit every valve spring
and if it won't and its to hard I'll fasion a jig that goes under the frame,
maybe on a bar so it can slide along, all one has to do is look see and make it.
I'm just kind of getting that way these days. Let no obstacle get in the way,
we wanna ride right. If these things blew up right away we'd be idiots, but
there worth it.
Which brings me to another matter, or two.
R6 wherever you are, youbetter HITITHARD, my engine is coming on like a
freight train from from eight on and man does it cover DISTANCE FAST.
Son of a gun that thing moves. When everthing hits it's there, I know
it is.
But. I'm going over to the old guys shop and I"m gonna sync those
carbs. I can't wait to see where they're at. I on it.
If I can't seem to get the carbs the way I need them to operate, I'll
attack the slides with a vengance.
I see they flutter, that's not good. I can fix that somehow.
After the pods are on and they are tuned I'll know if that's needed.
Carbs are a little glitchy, no real dead spots I can tell they arn't
delivering the same or vacuum amonst each other.
Once they are synched I really won't care what they do, I know the
power will be awesome and all the way up to it will be pleasant and
strong.
Enough to wail my way alongside and past the mighty 600's.
I just know it's gonna happen. TAKE IT TO THE TRACK BOY!
Yes sir, that's my plan, and according to plan, I'm right on schedule.
Schedule1 NARCOTICS you say? Blashfemme! The village idiot was hung a long
time ago and I'm not even related.
This no tournement, this for real. Ehem....
Got back from my second ride just awhile ago, the motor quit smoking.
I don't see any smoke, so I'm snickering inside some, and have those
butterflys coming up from down deep. Because I know. I know what's
coming, I can feel the power, I don't crap falling off, leaking,,
starting on fire. Last year I was a class A road hazard practically.
This year I'm on fire! destined to stay alive, well, and above and
beyond even my own expections.
And I have my old head to port even more radical :woohoo:
So when it gets all done I can't help but share and will post
pictures.
And there will video allright. I could never resist that.
And when you see the video, ask yourself, can my bike do that?
You don't have to answer, just bow down and say you did it man.
All stories need great endings right? Well I'm trying to make it
happen.
I just set my first foot down on top of the hill. Feels good.
It's like being home. nothing beats being in control of yourself, your mind,
and your surroundings, so you know what your made of what your capable of doing.
FROM DREAMS TO REALITY! Everyone raise a flag! RAHHHHHHHHHHHHHH! :woohoo:
  • nads.com
12 Jun 2012 00:40
#528389
Im in like flin. And I cut off that stupid large section of cone
from that kerker. That last end piece. What were they thinking.
No you can't ask me that :woohoo: So now make a little baffle
and WHAM! Transformation. Rocket man lives and rides a kz.
He's fll ION!
OHHH YEAH BABY!
YEAH
UH!
Yor opponent is down, your looking into face, lying there unconcious,
he's pathetic, your edrenaline is pumping, it's over, you WON!
The door opens, theres an even bigger opponent,
son of a..
you hide behind yourgirlfriend, who takes a mighty swing at his nuts,
down he goes.
And says "I thought I taught you how to fight.
WELL GEEZE, I,,, shut up and go get me some beer.
  • wireman
  • wireman's Avatar
12 Jun 2012 00:55
#528392
Attachment imagesCANTRYQV.jpg not found
:woohoo:
  • z1kzonly
  • z1kzonly's Avatar
12 Jun 2012 01:09
#528397
What the deuce?
WT"M"F?
How did a crank turn into valve seals?
Hank the Crank? he used to work 3rd shift at the printing plant I worked at for 33 years.
That was 20 yrs ago. His name was Hank, But why do you think theay called him "Crank" , he kept half the readers digest bindery going all night for days!
Now that is a tangent!
  • turboguzzi
  • turboguzzi's Avatar
12 Jun 2012 09:04
#528439
nads, the grease poet
  • nads.com
12 Jun 2012 19:16
#528595
I can't tell the crank is heavier. :)
I went over to the old guys shop and he hooked up his guages.
What a DISASTER! In no time at all it was running so bad.
He sety the idle mix at one and a half to start and I warned him.
No he didn't listen and the idle went up and down like It always did.
Finally convinced him to set them at 2 and a half.
but it was too late he had every carb screwed up and 4 had no vac.
I told him that's alright, no problem the linkage is probably screwed up.
He's doing this for free and I have respect so I taking it in stride.
I took them off and they were :blink: I synched them myself and
GUYS. OH MY GOOSH! It idles below 1000 like never before.
I took it out and hit it , the back end was squirrelling all over
tire roasting and WHOOOOOOO HOOOOOOO! What a deal!
I have never felt that kind of power. And I know for a fact
if I put those gauges back on, the vacuum would be perfect, my eyes don't
lie.
I am one happy camper.
And the oil smoke is ever present(was an oversight).
So it's back to valve seals and springs.
I have me some see erious power. The response is awesome, and at 8000
it will .... lets say hang on and don't miss the shift!
That zx6 I raced would not have a chance with this bike now, hands down.
The r6 I raced last summer with the inexperienced rider, I could not find
the bike on the net that had the undertail exhaust.
It was because the bike I raced was the tamed version of an r6.
But what do I care? Not at all. If that yami can handle this bike
I'll be a monkeys uncle. I know exactly what I'm talking about.
FEROCIOUS! :P Now back to salvage the rest of my relationship...
and make the bike look nice and all that. Just found the fiberglass
resin I thought I threw away, so It's on. :angry:
  • LarryC
  • LarryC's Avatar
12 Jun 2012 21:23 - 12 Jun 2012 21:33
#528623
nads.com wrote: I can't tell the crank is heavier. :)
lie.
GoNads! You either got 'em or you don't....ain't no inbetween :woohoo:
Larry C.
Last edit: 12 Jun 2012 21:33 by LarryC.
