Not Good
18 May 2012 01:36 #523049 by GPZ Buggy
Not Good was created by GPZ Buggy
Ok for those of you that don't know I put a GPz 750 motor in a buggy frame. I'm in the process of starting and tuning it and I noticed today that there is a good amount of oil in the exhaust. I know this is not good but can anyone pinpoint what the problem is? I'm thinking bad rings.
A little history
The motor is out of a 1984 Kawasaki GPz 750
It has 38K miles on it
It's oil cooled which I'm still using on the buggy.
18 May 2012 01:43 #523051 by MFolks
Replied by MFolks on topic Not Good
Do a cold compression check first,write doen the numbers, then remove the sparkplugs & add a small amount of oil (maybe a teaspoon) and reinstall the sparkplugs and do the compression check again.
If there is a noticeable increase in compression, it might be piston ring and hone time.Usually when the engine is apart, valve guides get checked,valve stem seals get replaced and the cam chain may or may not be replaced(depending on how much stretch is found).
18 May 2012 01:50 #523052 by MDawnz1
Replied by MDawnz1 on topic Not Good
Oh Man,
I have so many questions to ask that you left unanswered.
How did it run before you put it in ?
How much oil is in it ?
Wet oil? Like dripping out? Or just smoking?
The more info we have helps alot.
1974 Z1a, still 903
18 May 2012 01:52 - 18 May 2012 01:55 #523053 by Patton
Replied by Patton on topic Not Good
Even where compression tests okay, worn valve stem seals may allow oil into the combustion chambers.
And would also examine the crankcase oil for possible fuel contamination.
Good Fortune! :)
Last edit: 18 May 2012 01:55 by Patton.
18 May 2012 07:35 - 18 May 2012 07:45 #523064 by LarryC
Replied by LarryC on topic Not Good
Did the motor recently get a Wiseco big bore kit installed in it?
Does it blow oil droplets out the pipe?
If so, overlapped oil control rings are a strong possibility.
Larry C.
Last edit: 18 May 2012 07:45 by LarryC.
18 May 2012 10:41 #523089 by GPZ Buggy
Replied by GPZ Buggy on topic Not Good
Oh Man,
I bought the entire bike from a guy las summer and I sat and listened to it run for 5-8 min. It then sat for about 8 months during the transplant.
The bike has the recommended amount of oil in it. If you look at the little oil window on the side of the Ike it is full.
Wet oil dripping out and smoke coming out .
  • Kawickrice
18 May 2012 11:24 #523099 by Kawickrice
Replied by Kawickrice on topic Not Good
We need pics of the Buggy
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
18 May 2012 11:46 - 18 May 2012 11:50 #523106 by GPZ Buggy
Here you go.
Attachment FinishedexhaustwithFuelCell.jpg not found
Last edit: 18 May 2012 11:50 by GPZ Buggy.
  • Kawickrice
18 May 2012 12:03 - 18 May 2012 12:05 #523111 by Kawickrice
I like it. How does the power transfer from the motor the the rear end
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 18 May 2012 12:05 by Kawickrice.
18 May 2012 12:20 #523113 by baldy110
Replied by baldy110 on topic Not Good
How do you cool that engine, it's an air cooled engine, not oil cooled. It has an oil cooler but that is not the primary method of cooling. It relies on the flow of air passing over the fins.
18 May 2012 12:44 #523120 by Patton
GPZ Buggy wrote: ...motor is out of a 1984 Kawasaki GPz 750...oil cooled which I'm still using on the buggy.
:unsure: With air flow being more restricted over the rear-mounted engine, are there any enhancements to cooling, such as some sort of fan or blower to move air over the engine fins and/or over the stock oil-cooler?
Good Fortune! :)
18 May 2012 13:02 #523126 by 650ed
Replied by 650ed on topic Not Good
Cooling that puppy is going to be tough. Not only is the air blocked by the buggy's chassis and driver/passenger, but the engine is mounted backwards. Whatever air makes it through will be hitting the back of the engine rather than the front, and the engine designed to cool from the front. It will for sure need some serious fans to keep it from getting too hot. Maybe a liquid cooled engine would have been a better choice. :unsure:
