Your Thoughts on Engine Wear? Good pics.
- DoubleDub
- Visitor
06 May 2012 23:18 #520377
by DoubleDub
Replied by DoubleDub on topic Your Thoughts on Engine Wear? Good pics.
Possibly from lack of oil - possibly why there was scoring on the cam bearing too?
- Jay98
06 May 2012 23:38 #520384
by Jay98
Replied by Jay98 on topic Your Thoughts on Engine Wear? Good pics.
It did smell pretty burnt(oil) inside the valve cover when I removed it. So, any other reason for that besides a plugged oil passage?
- DoubleDub
- Visitor
07 May 2012 06:48 #520433
by DoubleDub
Low pressure, low oil, blocked passage.
Jay98 wrote: It did smell pretty burnt(oil) inside the valve cover when I removed it. So, any other reason for that besides a plugged oil passage?
- Thank you received: 2098
07 May 2012 10:35 #520457
by Patton
Replied by Patton on topic Your Thoughts on Engine Wear? Good pics.
Another possibility could be from running with fuel-contaminated oil.
- Jay98
07 May 2012 11:17 #520467
by Jay98
The oil did smell like fuel, what are my possibilities with that. I thought maybe it was flooded because they tried to start it quite a bit with bad gas and couldn't get it running.
Patton wrote: Another possibility could be from running with fuel-contaminated oil.
07 May 2012 13:12 #520490
by Patton
And not run the engine until all float valves are properly functioning.
Should change oil and filter.Jay98 wrote:
The oil did smell like fuel, what are my possibilities with that. I thought maybe it was flooded because they tried to start it quite a bit with bad gas and couldn't get it running.Patton wrote: Another possibility could be from running with fuel-contaminated oil.
