Your Thoughts on Engine Wear? Good pics.
- Jay98
- Jay98
- wireman
- Thank you received: 299
- Jay98
- bountyhunter
- Thank you received: 337
I don't know if the scoring on the right hand cam journal is a problem, you need to plastigauge it for wear. It doesn't look good.
- DoubleDub
- Visitor
- Jay98
- gd4now
- Denco where did you go?
- Thank you received: 440
What does the cap look like, and what does the cam look like? Are they scored as well? As others have said you need to measure (plastigauge)it to see if it is still within spec. Would also suggest measuring cam to see if it is still in spec as well.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- wireman
It would have told you if you actually needed rings or a valve job.Jay98 wrote: No. Why would that matter if I'm redoing the rings, checking the bores, honing the cylinders and redoing the valve seals?
Since youve already got it torn down flip the head on its back side so exhuat ports are pointing up then fill exhuast ports full of solvent.
Then take an air hose with one of those blow gun things on it and blow around the outside edge of exhuast vales where they meet the head.
If you dont see any bubbles in the solvent you know the valves are doing a decent job of sealing,then flip the head the other way and repeat on intake valves.
- wireman
That journal scares me
- DoubleDub
- Visitor
wireman wrote: Is there cam bearings that go in that head or does it just ride on the casting?
Looks like an insert in the photo, but hard to tell.
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
I thought it looked like a bearing sitting in there too. The other two have no visible ledge like the third does.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
