Your Thoughts on Engine Wear? Good pics.
- Jay98
- gd4now
- Denco where did you go?
- Thank you received: 440
Are the pics of the cam both of the same end or opposite ends?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- bountyhunter
- Thank you received: 337
- bountyhunter
Pretty sure the twins use no inserts. The 750 twin has no inserts at all.DoubleDub wrote:
wireman wrote: Is there cam bearings that go in that head or does it just ride on the casting?
That journal scares me
Looks like an insert in the photo, but hard to tell.
- Jay98
the first picture is the cap for the scored journal. All caps look good. and that is opposite ends on the cam shaft.gd4now wrote: Which cap picture is the one from the problem journal? None of them look too bad, at least not in the pics. But that could just be the angle of the pics. Looks like all of the scoring was on the head and not on the cap.
- Jay98
- Old Man Rock
- Thank you received: 225
Attachment SimpleGreen.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Perhaps some excess sealer came loose and clogged an oil passage.Jay98 wrote: I saw no signs of anything that could scratch anything, but this easily could have been an old scar from a previous repair because the head had been resealed before. high temp gasket maker inside the edges of the head.
- Jay98
- P21
- Thank you received: 34
Attachment IMG_6048.jpg not found
oil holes on cam are in yellow make sure there open
Kawasaki KZ 1000 Police (2002) P21
- P21
Attachment IMG_6035.jpg not found
something is funky here dont look right like it got hot
- Jay98
