- Thank you received: 47
early KZ cam cover on MKII head??
- BlackZ1R
- Kawasaki in my blood
zed1015 wrote:
BlackZ1R wrote:
Jeff.Saunders wrote: The top idler assembly on the Mk II is constructed differently than the earlier version. The later valve covers have a bulge around the center section of the cover to accomodate. You cannot use a Z1 cover with that style of top idler assembly.
I spent far too much time bead blasting a cover from my turbo bike only to find the issue first hand...
Ahhhhh, D'oh!!! That sucks.
I reckon I can grab a new top idler if I decide to do this.
I've got an '80 LTD that I would like to clone into a '76 for some reason. :silly:
I really just like the looks of the early cam covers.
Why not use a 1000a cover ?
They have the round styling and take the later idler.
You can always polish out the half moon casting on the end to mimic the the very early cover.
I just went and looked at my cover. It appears to be a 1000a cover with the raised section in the center, so I can use my late model(1980) idler, correct?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Thank you received: 2065
If concerned with clearance Mock it up with clay on top of idler to check it.
- Thank you received: 2098
Patton wrote:
BlackZ1R wrote:
Looks good Patton. Care to expound on that photographic presentation? :whistle:Patton wrote:
Have so far been unsuccessful in locating the KZr forum thread where that pic was posted as an example of tapping the clean air ports in the head and inserting a screw to serve as a plug.
Here's another thread dealing with the subject of plugging the ports in the head.
www.kzrider.com/forum/2-engine/78496-smo...d-exhaust-port#78496
Found the link, and more:
www.kzrider.com/forum/11-projects/502232...e-off-project#502232
www.kzrider.com/forum/2-engine/500625-re...from-their-kz#500625
www.kzrider.com/forum/2-engine/233524-re...head-question#233524
www.kzrider.com/forum/2-engine/221581-re...4-z1-900-head#221581
www.kzrider.com/forum/2-engine/56489-rel...g-head-on-a-77#56489
- zed1015
- Thank you received: 1561
Yes
It's only the very early z1 Covers that need the early idlers.
The early covers have a more flat sided raised section with no added 'bump' either side.
The later 900 and 1000 covers have those added 'bumps' and even though there are a few different design idlers, They will all fit with the later cover.
- BlackZ1R
Street Fighter LTD wrote: Black Z1R
Ahh, no clay needed. Looks like I have the right cover for what I'm doing.
Thanks for all the replies guys.
Kawasaki
- toad
- Thank you received: 7
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
