early KZ cam cover on MKII head??
  • BlackZ1R
  • Topic Author
  • Kawasaki in my blood
03 May 2012 15:42 - 03 May 2012 17:05 #519598 by BlackZ1R
early KZ cam cover on MKII head?? was created by BlackZ1R
I haven't tried this, but was told that the early style Z/KZ 900/1000 cam cover will work on the MKII 1000 head if the smog ports are blocked off.
Just looking at the rocker cover sitting on the head, it looks like it is a go.
Anyone here done this one?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Last edit: 03 May 2012 17:05 by BlackZ1R. Reason: rocker to cam. rockers are for Chevys
03 May 2012 17:00 #519612 by roy-b-boy-b
Replied by roy-b-boy-b on topic early KZ rocker cover on MKII head??
I run the early style on all my bikes. I think there was mentioned a taller cam tower being too tall. If you got it on and the engine is in the frame it will probably work.
If you notice bits of metal in the oil pan it is the Xs on the cam cover being rubbed off. Don't ask how I know. :ohmy:
Or grind them off or use two gaskets.
  • BlackZ1R
  • Topic Author
03 May 2012 17:07 #519615 by BlackZ1R
Replied by BlackZ1R on topic early KZ rocker cover on MKII head??
roy-b-boy-b wrote: I run the early style on all my bikes. I think there was mentioned a taller cam tower being too tall. If you got it on and the engine is in the frame it will probably work.
:laugh: 10-4. I see where you're coming from ;) That would kinda suck. hate it for ya bro. What are you plugging the smog ports with?
11/32 drill bit fits the hole pretty good.
Kawasaki
03 May 2012 17:20 #519621 by 531blackbanshee
Replied by 531blackbanshee on topic early KZ rocker cover on MKII head??
once upon a time when i was young(er) and dumb(er) i used .38 special cases coated with jb weld and drove them into the holes for the smog ports :pinch:.
it worked,but i think i could come up with a more elegant solution nowadays.
03 May 2012 18:00 - 03 May 2012 20:29 #519633 by zed1015
Replied by zed1015 on topic early KZ cam cover on MKII head??
Smog ports in head will straight tap M10 without having to tap drill and plug with grub screws.
Early camcover will bolt straight on.
Very early cover will need early top idler too.
Last edit: 03 May 2012 20:29 by zed1015.
03 May 2012 18:01 #519634 by Patton
Replied by Patton on topic early KZ rocker cover on MKII head??
Good Fortune! :)
03 May 2012 20:22 #519659 by Jeff.Saunders
Replied by Jeff.Saunders on topic early KZ rocker cover on MKII head??
The top idler assembly on the Mk II is constructed differently than the earlier version. The later valve covers have a bulge around the center section of the cover to accomodate. You cannot use a Z1 cover with that style of top idler assembly.
I spent far too much time bead blasting a cover from my turbo bike only to find the issue first hand...
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • BlackZ1R
  • Topic Author
04 May 2012 00:53 #519733 by BlackZ1R
Patton wrote:
Good Fortune! :)
Looks good Patton. Care to expound on that photographic presentation? :whistle: :cheer:
Kawasaki
  • BlackZ1R
  • Topic Author
04 May 2012 01:01 #519736 by BlackZ1R
Jeff.Saunders wrote: The top idler assembly on the Mk II is constructed differently than the earlier version. The later valve covers have a bulge around the center section of the cover to accomodate. You cannot use a Z1 cover with that style of top idler assembly.
Ahhhhh, D'oh!!! That sucks.
I reckon I can grab a new top idler if I decide to do this.
I've got an '80 LTD that I would like to clone into a '76 for some reason. :silly:
I really just like the looks of the early cam covers. :cheer:
Kawasaki
04 May 2012 07:40 #519753 by Patton
BlackZ1R wrote:
Patton wrote:
Good Fortune! :)
Have so far been unsuccessful in locating the KZr forum thread where that pic was posted as an example of tapping the clean air ports in the head and inserting a screw to serve as a plug.
Here's another thread dealing with the subject of plugging the ports in the head.
www.kzrider.com/forum/2-engine/78496-smo...d-exhaust-port#78496
Good Fortune! :)
The following user(s) said Thank You: BlackZ1R
04 May 2012 07:50 - 04 May 2012 07:50 #519756 by zed1015
Replied by zed1015 on topic early KZ rocker cover on MKII head??
Why not use a 1000a cover ?
They have the round styling and take the later idler.
You can always polish out the half moon casting on the end to mimic the the very early cover.
Last edit: 04 May 2012 07:50 by zed1015.
04 May 2012 08:04 #519759 by roy-b-boy-b
Could anyone post a picture of the two idler assemblies? Roy
