- Thank you received: 1616
Cam caps
- loudhvx
650ed wrote: You should contact the seller and see if he can possibly find the cam caps. The journal for the cam in the cam caps and head are machined together, so using caps from another head may lead to problems. I'm not saying it cannot be done, but if possible always keep the head and caps together.
+1
Even caps from the same motor often won't swap from position to position.
I have 2 motors that were given to me where all of the caps were mixed together and it took a long time to get the caps matched to the head they came from.
I'd hate to think what it would be like matching caps from totally different motors.
You can install them and feel if there is a bump at the mating surface or not, but even if smooth, that won't necessarily mean the hole is round.
That said, I know people here have done it, presumably with success.
I don't think line boring will help since you might have to take off to much material. Does anyone make cams with oversize journals?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
A shop that align bores blocks wouldn't necessarily align bore your head. Not the same machine used to do this operation.
Call some of the head shops that advertise here and ask for their advice. They will know exactly what you're up against. Like you stated earlier, you paid $100 for the head. If you can use some of the parts, good for you. If not, sell it as a non complete head to the next guy that can use it as it is.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Thank you received: 797
which makes the hole oval and then go back in and re-machine the hole hopefully just bareley brushing the head side and taking most of the meat outta the cap.which leaves the hole the same size as before.
hth,
- loudhvx
531blackbanshee wrote: they machine the bottoms of the caps lou.
hth,
Ahhh. Thanks Leon.
Seems like a pretty tricky job to pull off.
But what if the cap is not centered left to right (when viewed from side of engine)? That's what I noticed about mismatched caps when I was juggling them.
1981 KZ550 D1 gpz.
Other links.
hth,
Ahhh. Thanks Leon.
eww,not good lou. :sick:
hopefully they have enough meat in em to cut enough away and still have the needed strength. :pinch:
otherwise get friendly with a machinist and get some custom caps machined. :laugh:
- rustedcutlery
And another question, it's seams like all the j heads go for around ~$200 on eBay, is that about what fair market value is?
- loudhvx
Well, that was only while I was sorting the caps. I eventually got them matched to their original locations and all was smooth.531blackbanshee wrote:
eww,not good lou. :sick:loudhvx wrote:
Ahhh. Thanks Leon.531blackbanshee wrote: they machine the bottoms of the caps lou.
hth,
1981 KZ550 D1 gpz.
Other links.
