- Thank you received: 2
An odd Rattle...
- Robwolf
- It's ugly, but it moves!
04 Jan 2012 16:43 #496306
by Robwolf
'79 Kz400H1 'cafe' and '94 En500 Vulcan in swampy Florida.
Replied by Robwolf on topic An odd Rattle...
I have peiced it back together again with the nice clean head. Adjusted my clearances and have gained about 30 lbs of pressure on #1(left) cyl. 120 left 150 right havn't got the rings or rod bearings on yet, or the new gasket (didn't want to waste my gasket for a quick test.) I'm going to try getting the .5 or maybe 1mm OS rings from an older model and hope they fit. I'm very confused on these parts.
- Fritula
- holly land garage
12 Jan 2012 12:52 - 12 Jan 2012 12:52 #497742
by Fritula
Replied by Fritula on topic An odd Rattle...
In my book it should be idling at 1000 rpm
Last edit: 12 Jan 2012 12:52 by Fritula.
- Robwolf
25 Jul 2012 23:10 #538681
by Robwolf
Alright! I've stopped being a wuss and opened up the crank case. The engine trouble was indeed caused by a slipped bearing. The left side bearings were trashed! I've replaced them. I do need to replace the front cam chain guide because the plastic on it fell apart. Ordered it already so waiting for it. Have the new gaskets waiting. So while I wait for the part I'll inspect and clean other parts of the engine.
