- Thank you received: 2
An odd Rattle...
- Robwolf
- It's ugly, but it moves!
'79 Kz400H1 'cafe' and '94 En500 Vulcan in swampy Florida.
- P21
- Thank you received: 34
that will let you know what is happening
pull all plugs out and wide open throttle when doing test
Kawasaki KZ 1000 Police (2002) P21
- P21
but when clutch rises hell you know it
- Robwolf
- Thank you received: 2098
Robwolf wrote: ... noticeable movement on the plug....
Is the plug broken, or loose, or stripped plug hole threads?
- Robwolf
Robwolf wrote: Ok, plug was loose....
Should not run the engine with a loose spark plug.
- Robwolf
- Robwolf
- Thank you received: 2829
- P21
this picture just only referance www.kz400.com/KZ440MaintainanceFrameset.html
