- Thank you received: 1616
1980 550LTD Clean Cafe Build
- loudhvx
I supose it could also be the oil-pan gasket too, but it looks like the oil is coming from higher up (out of photo).
To really find what is leaking, remove the sprocket cover, take the chain off.
Hit the whole area with some engine degreaser and rinse off lightly with water.
Then run the bike on a center stand for a little while and see if the oil leak reveals itself.
Once again, not difficlut, but time consuming.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- djplatinum50
1980 Kawasaki KZ550C1 LTD
- loudhvx
Not sure.djplatinum50 wrote: okay ill give that a try this weekend. Do you think it would be wise to just buy a whole engine gasket kit, and just replace all of that?
I think it would be cheaper to get the seals separately, but I haven't looked into it.
Also, very carefully remove the clutch pushrod and make sure it's straight. There is a ball bearing at the other end which may or may not come out with the push rod, so make sure to catch it if it comes out.
1981 KZ550 D1 gpz.
Other links.
- djplatinum50
Thanks for all your help
- djplatinum50
- ultimate fighter
love building motorcycles one headache at a time
- loudhvx
But it sounds like there may be other issues if you're geting black smoke. Maybe the main is too big, or the throttle stop is set too far beyond 100% open, or maybe there is a float level or float valve issue. If anything it should have been pretty lean. I would expect you should be on the 3rd clip from the top on the needle.
This set will do the pilots and the mains up to 99.
1981 KZ550 D1 gpz.
Other links.
- djplatinum50
- ultimate fighter
- djplatinum50
ultimate fighter wrote: there is always a better way than drilling jets...
Im all ears
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- djplatinum50
question whats your opinion on using a liquid gasket maker say on the transmission cover where I may have a small oil leak??
