What is the best oil for a 77 kz1000?
- kz750saskatoon
Re: What is the best oil for a 77 kz1000?
18 May 2011 15:20 - 18 May 2011 15:23
Is the oil at the following link what we are all talking about?
Shell Rotella T
Just wanted to double check because it sounds like the bottle is white down in the US. Also, it sounds like I should be looking for some 15W40 for my KZ750? The fill cap says 5W40 I think? Would I still need a ZDDP additive with this?
1981 KZ750-H2
Saskatoon, SK
Saskatoon, SK
Last edit: 18 May 2011 15:23 by kz750saskatoon.
- bountyhunter
18 May 2011 15:50 - 18 May 2011 15:53The cap on my KZ-750 says 10-40, but the manual also mentions 20-50 which I assume is for hotter weather. I run 10-40 winter and a 50-50 mix of 10-40 and 20-50 for summer.kz750saskatoon wrote: Is the oil at the following link what we are all talking about? Shell Rotella T
I would not run 5-40 because it is 5W base oil with enough viscosity increasers to jack it up to 40W at hot temps. An 8:1 ratio means a lot of VI's which present two issues:
1) VI's are not oil and the amount of volume they displace is not a lubricant.
2) VI's get torn apart by the gearbox so the oil gradually turns back into 5W over time.
IMHO, I think people make the oil thing more complicated than it is. I recommend buying any good quality 10-40 dino oil on sale (or at Wal-Mart) and just change it frequently like 1500-2k mile intervals or six months whichever comes first. The base oil does not fail, it's the additives. Changing frequently will make sure the additives don't run out and will also keep the engine cleaner. Just my opinion.
I believe Rotella still has ZDDP in it but I don't know for sure. Read the service grade off the bottle: if it says SM or SN, you must add ZDDP. Other grades have some but exactly how much varies by manufacturer.
Last edit: 18 May 2011 15:53 by bountyhunter.
- T_Dub
18 May 2011 16:15
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- otakar
18 May 2011 16:25kz750saskatoon wrote: Is the oil at the following link what we are all talking about? Shell Rotella T
Yes, that is the synthetic version of it. 5W-40 is fine since the 5W is the winter viscosity and the 40 is the summer viscosity. Even 0W-30 would not hurt your bike even a little bit since the 30 is what concerns you. You can run the stuff in the white bottle just as well if you do not want to run synthetic.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- zed1015
18 May 2011 19:57
Any decent 10w40 will do, Silkolene Super 4 / GTX etc or you could go for Rock oil TRM 20/60 if it's a tuned motor,
It's specially formulated for roller bearing cranks which is what i run in mine.
- KZ1000LTDPENNSYLVANIA
16 Jul 2018 18:03
I googled Shell Rotella T and it says diesel... is this ok to use on a gas?
Also, I was in Walmart and they only had synthetic.
Not sure if it’s ok to switch when my bike’s been used to regular conventional oil for 39 years.
Thoughts on diesel oil or synthetic oil?
1979 KZ1000 LTD
16 Jul 2018 19:14KZ1000LTDPENNSYLVANIA wrote: I googled Shell Rotella T and it says diesel... is this ok to use on a gas?
Shell Rotella Diesel works just fine . I use dino / non synthetic , but synthetic is good too
Dont over think it.
The following user(s) said Thank You: KZ1000LTDPENNSYLVANIA
17 Jul 2018 08:40
Quite a few guys run Rotella in our bikes with no problems. The easiest way to be sure an oil is appropriate for a wet clutch motorcycle is to look for the JASO-MA rating. Fully synthetic is just fine, but not necessary.
