What is the best oil for a 77 kz1000?
- wdizard
15 May 2011 19:32
What is the best oil for a 77 kz1000?:dry:
- roy-b-boy-b
Re: What is the best oil for a 77 kz1000?
15 May 2011 20:29
You need to search that subject. It is probably in the top five discussions and there is probably 500 responses to that question. Roy
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
15 May 2011 20:50
I second the 'search the site' but would add (as you're sure to find) that the bike was engineered to run an SAE type, and unless the motor's in a non-stock or worn out configuration, the Kawasaki factory hated warranty claims and always over-engineered their bike. Assuming a stock bike and in decent internal mechanical condition, the factory shop manual tells you what oil Kawasaki thought would give the engine the longest life/least chance of warranty claims.
I have a '78 Kz1000 A2 and my fsm says to run with SAE 10w40.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- MFolks
15 May 2011 20:53
I'd suggest the Shell Rotella "T" oil in 15W40 weight.
- wireman
15 May 2011 21:08
any clean oil is the best oil,most expensive oil in the world is no better than cheap oil if its not changed regularly
- trianglelaguna
15 May 2011 21:19MFolks wrote: I'd suggest the Shell Rotella "T" oil in 15W40 weight.
i get that and other good oils at wal mart and change em a lot and change the filter a lot too...
they are a deal there and i can afford to change it often..
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- andy9802gt
- If it tastes that good, eat it yourself.
15 May 2011 23:28
Good old decomposed dinosaur is the best. Pick a flavor and run with it. I run yamalube 20w50 in mine.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Polar_Bus
16 May 2011 09:28 - 16 May 2011 09:34
Why do so many motorcyclists loose sleep over "what oil" to run in their bike ? The average engine lifespan of the average street driven motorcycle is say 15-20K ? Yet I NEVER read a post about people loosing sleep over "what type of oil should I run in my 170K mi. Honda Civic automobile ?
I've tried every OEM brand of mineral based oil and I don't notice any dam difference between them... I don't run synthetics in a wet clutch motorcycle engine, and I like Kawi 10w-40 becuase it's priced very reasonable, and my Kawi dealer is 15 min from my house.
I run the Kawi oil in all my bikes reguardless of make, even in my chineese pitbike !
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
Last edit: 16 May 2011 09:34 by Polar_Bus.
- mtkawboy
16 May 2011 13:59
Ive run 20/50 Castrol GTX oil in all my Kaws since my first 73 Z1. I have an 1105 engine in one thats been running since 1977 and still hauls butt. Youll get 1000 opinions on oil.
Last edit: 14 Feb 2013 11:19 by martin_csr.
- wireman
16 May 2011 15:19
OTTO-TIVES! :woohoo:
- Darkangel
16 May 2011 16:41
I've used castrol GTX in my bikes...all of them that I've had. With good results. Has anyone ever used GTX High Mileage in their old kaw?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
