Possible bent valve?
  • Bullitt03737
  • Bullitt03737's Avatar Topic Author
25 Mar 2011 01:07
#440289
Me and my dad where going through checking valve clearances on the csr 1000. We where using the motion pro tool and we came up with .003 it was a little tight so we put a slightly smaller shim in. When I removed the tool from under the cam and the bucket did not come all the way back up. now theres about a 1/16" gap.
Is it possible that the motion pro tool caused a piston to valve contact bending the valve and now it wont close all the way?
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
  • wireman
  • wireman's Avatar
Re: Possible bent valve?
25 Mar 2011 02:40
#440297
it would be pretty tough to get enough leverage with that short little tool to bend a valve i would think anyway,will the bucket spin?
did you spin motor over through a hard spot? dont turn motor over with that bucket stuck down .
i wonder if the bucket got stuck in some carbon or something?
  • bountyhunter
  • bountyhunter's Avatar
25 Mar 2011 03:32 - 25 Mar 2011 03:33
#440302
I think the tool couldn't possibly have enough leverage to bend a valve using it. However, if you had the "wedge" in place between the camshaft and the top of the bucket and turned the crankshaft using a wrench you might bend a valve.
Last edit: 25 Mar 2011 03:33 by bountyhunter.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
25 Mar 2011 10:09
#440328
possibly you burred/dinged the edge of the bucket bore with the tool and it is hung on the burr.
just a thought,
  • Old Man Rock
  • Old Man Rock's Avatar
25 Mar 2011 10:39
#440333
Leak Down test would tell all.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 531blackbanshee
  • Vendor
  • Vendor
25 Mar 2011 12:35
#440345
Old Man Rock wrote: Leak Down test would tell all.... ;)
he already knows the valve is hung open dave :whistle: .
he is trying to figure out why, :pinch: .
:P leon
  • Old Man Rock
25 Mar 2011 16:08
#440370
Leon........... :angry: :laugh: :laugh: :laugh:
Concept I was going after was to see if filling the chamber with air would possibly blow any pariculates/matter up and out....
Also with testing the other chambers/valves, requires 180 rotations of the crankshaft.... Wtih some engine pre-lube or lubricants in the valve springs and such, might be able to see where and why it's sticking open...
Just a thought, no biggy....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Mar 2011 17:56
#440408
531blackbanshee wrote: possibly you burred/dinged the edge of the bucket bore with the tool and it is hung on the burr.
just a thought,
Good thought Leon.
can u reinsert the shim tol to lower the bucket and check? or use another lever to push the bucket down? make sure the piston is not near tdc though.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Bullitt03737
26 Mar 2011 01:53
#440495
:blush:
Well! Dad turned the number one piston through the valve. Bending it, and cracking the guide. After a few hours of tolling we had the guy at the local shop find a guide and put it in for us.
So thats why the bucket wouldn't close all the way! All is well now and the engine is timed, shimmed, and back together. Just gotta reinstall carbs, exhaust, coils, wires, and tank. OH and change the oil. Shame its going to snow tomorrow.
  • Harvey1327
  • Harvey1327's Avatar
26 Mar 2011 01:57
#440497
Bloody dads can't live with em can't live without em ;)
haven't you got spikes ;)
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • Bullitt03737
26 Mar 2011 02:20
#440500
Live and learn right? It was a learning experience. The engine is fresh once again with new rings a good hone, 3 angle valve job. New valve seals. Can't wait to fire it up!
  • wireman
  • wireman's Avatar
26 Mar 2011 02:29
#440503
well that was fast! B)
