Possible bent valve?
- Bullitt03737
Re: Possible bent valve?
26 Mar 2011 02:41
Not messing around on this one! As soon as this ones done I am on the hunt for the next project.. im thinking a big bore..
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- Old Man Rock
26 Mar 2011 11:27
Well time to turn it around and give ole dad a Life Savor... (Old farts like me will remember those commercials/slogans) for yeah, we screw up as well... :blush: :laugh:
Happy to hear you got her fixed up, another Kawi lives....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
26 Mar 2011 11:53Old Man Rock wrote: Well time to turn it around and give ole dad a Life Savor... (Old farts like me will remember those commercials/slogans) for yeah, we screw up as well... :blush: :laugh:
OMR
Maybe me too when I get as old as OMR. :pinch:
But meenwhile, I neber make misteaks.
- mark1122
- Keep twisting it
26 Mar 2011 13:07Bullitt03737 wrote: Live and learn right? It was a learning experience. The engine is fresh once again with new rings a good hone, 3 angle valve job. New valve seals. Can't wait to fire it up!
Just a heads up.
was the valve job done before or after u had to replace the guide? generally u need to do a valve job after u replace guides. the guides dont always go in true. u may want to do a leakdown test to verify seal if u did the v job first.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bullitt03737
27 Mar 2011 01:33
The valve job was done before the guide/valve was replaced. But we did do a leak down test on it and it seals quite nicely.
Tried starting the bike tonight and it just sputters and pops a little.
27 Mar 2011 06:28
Would be certain that cam timing is correct.
And that wire from 9 o'clock Dyna-S module signals coil firing outside plugs #1 and #4.
And that wire from 3 o'clock Dyna-S module signals coil firing inside plugs #2 and #3.
- mark1122
- Keep twisting it
27 Mar 2011 17:14
X2
sounds like timing.
sounds like timing.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bullitt03737
27 Mar 2011 20:58
Turns out the magnets behind the pickups where installed backwards. After that was switched up the bike fired right off. It had an extremely loud valve on the right side so we shut it down immediately and pulled the valve cover again. One of the cam caps had not gotten properly torqued down and was letting the cam rattle I guess. Fixed that re-shimmed it, put it back together and it is soo smooth and super quiet!!
Everyone knows one problem leads to another though, I took it out for a ride and oil started leaking past the copper washers on the four corners (they where not replaced, just cleaned up) so I brought her home and now need new copper washers.
- peter1958
27 Mar 2011 21:03
heat the washers till there red hot and toss in some water. they will swell up and you can use em again.
www.kzzone.com/
