how to install new gaskets
- TeK9iNe
- What did you do!?!
Re: how to install new gaskets
07 Mar 2011 11:04
Jeff.Saunders wrote:
Agreed. These can be a big PITA.
I pack the channel behind the rubber grommet absolutely solid with 1104/1194 goo... I usually do this little-by-little over several days as the goo shrinks when it dries.
Before I do this, I clean all the wires, the channel and grommet as thoroughly as possible.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- DoubleDub
07 Mar 2011 11:08
Yup, mine is dripping, as is typical. They put a ton of goo in there, but I think the grommet is the original on the bike and it still drips.
Do you guys typically run some Yamabond/1104/1194/etc. along the bottom half of the stator gasket to assist with the seal, or does it just tend to be the grommet that causes the leak if things are cleaned up and prepped properly?
- TeK9iNe
07 Mar 2011 11:10
Other than a good head gasket, I use 1104/1194 for just about everything now.
I dry fit everything first, checking gap with a 002" feeler guage. If its all OK, then i go ahead and wipe everything down with acetone/brake cleaner/oil free thinner/etc.
I like to put the stuff on my finger first, then just tack it lightly along both mating surfaces till its pretty thin and even with small peaks everywhere.
Never had a leak after this process.
Removal is fine, and I can often just reuse whats there with a quick smear of grease on the old goo, then re-assemble.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
07 Mar 2011 11:12
DoubleDub wrote:
Mostly gromet - I've had a very small intermittant drip through the actual wire holes, that every season seems to need a quick cleanup and re-goo. PITA.
If you want to use goo - remember, sparingly! Just a thin tacky film is erally all thats needed.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- DoubleDub
- Jeff.Saunders
07 Mar 2011 13:25
BTW, my favorite scraper is from Goodson - their Super Scraper. I was talking with them at the recent DealerExpo in Indy - they are going to release a narrower version for the motorcycle industry later this year. This is one of those MUST HAVE parts...
www.z1enterprises.com
Z1 Ent on Facebook,
- stonemaster
07 Mar 2011 15:13
put up on ur site ????
- Jeff.Saunders
07 Mar 2011 15:35 - 07 Mar 2011 15:36
Jeff, we'd like to be a Goodson distributor, but we'd never carry enough of their products to gain that status as most of their product is automotive and harley.
They are a good company to buy direct from. I've bought a couple of times for my own toolbox.
If anyone is interested:
www.goodson.com/
www.goodson.com/
Z1 Ent on Facebook,
Last edit: 07 Mar 2011 15:36 by Jeff.Saunders.
- jjdwoodman
- Live free, or die.
07 Mar 2011 15:40
I didn't see any mention of a brillo pad for gasket cleanup? I like it much better than hand scraping if room allows for a die grinder in there.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- andy9802gt
- If it tastes that good, eat it yourself.
07 Mar 2011 15:41
jjdwoodman wrote:
Amen to that. Red scotchbrite on a right angle die grinder.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- Topper
07 Mar 2011 18:38
I tell you what, every time I think "Well, I don't really need to bother those nice guys at KZRider with this" I wish I had.
That gasket sealant on the valve cover was a PITA and removing it all the next time I have to get in there is going to be worse.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- wireman
07 Mar 2011 18:46
yeah only thing i use on valve cover gasket is my tried and copper coat spray gasket
