gsxr750 carbs, with accel. pump.
  • notaduc
  • notaduc's Avatar Topic Author
06 Feb 2011 08:58 - 06 Feb 2011 08:59
#428949
I keep seeing these referred to as VM29ss, they are 32mm flatsides from the UK gsxr750 1985-1986. From what I can tell they are TM series. Spacing matches KZ1000 head.
Anyone familiar with them?
1980 (mostly) KZ1000
Last edit: 06 Feb 2011 08:59 by notaduc.
  • mjg15
  • mjg15's Avatar
Re: gsxr750 carbs, with accel. pump.
06 Feb 2011 09:05
#428952
If you have them , and want to get rid of them, I've been looking for set for my GSXR750.
Sorry not to be of any help otherwise
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • notaduc
06 Feb 2011 09:10
#428956
I do have them, not sure what I'm doing with them yet.
  • mjg15
  • mjg15's Avatar
06 Feb 2011 09:27
#428961
If you decide that you arent using them PM me. NO hurry, I was thinking of using them for a project that I won't be getting to for a while (GS1000S rep , using GSX750 motor/GS550 chassis). I've been trying to get a friend of mine in Ottowa to find me a set.
If you get a few minutes can you get some measurments for me?
I need spacing (center to center)between intake spigots and OD of spigots. My motor is actually a 2000 Katana 750, I just want to make sure that the spacing is the same, and that they didnt change the casting.
Thanks
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • notaduc
06 Feb 2011 09:34
#428966
I will likely keep them as I paid too much for them.
The motor side od is 38, the filter side is 50mm, spacing is 77-90-77
  • mjg15
  • mjg15's Avatar
06 Feb 2011 18:57
#429066
Thanks for the dimensions. I have a set of RS34's that I can use, but I have been looking for a set of those GSXR carbs. Where did you find that set?
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • TerryK
  • TerryK's Avatar
06 Feb 2011 19:28 - 06 Feb 2011 19:30
#429076
Very!! I've been running them on my 1075 for years. They were also on Canadian models and were called "slingshot" carbs. If you put GPZ flanges on the head they bolt right up. Cable routing is a bit of an issue as the cables will hit the KZ tank. You have to carefully bend the cable mount forward to help them clear. You'll need to get someone to make you custom cables as well. Also, keep in mind these carbs were designed to work in a semi-downdraft application so you will have to set the float heights accordingly. I believe I had to set the floats a bit lower(lower fuel level) to keep them from constantly overflowing.
I have all the jetting specs I used but that may be different for your application but at least you will have a starting point. I also have a tuning manual for them that I could copy for you. I know all this sounds complicated but it's worth in in the end. These things run great on my bike once jetted correctly.
I also suggest you use the "constant torque" style hose clamps. They work perfectly and easily and you will need a good clamp because you will be taking these carbs off a few times until you figure out your jetting. Plus they look cool as hell! :P Try to find them with allen socket or philips head.
Let me know if I can help with anything else.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 06 Feb 2011 19:30 by TerryK.
  • notaduc
06 Feb 2011 19:39
#429080
ebay uk
  • notaduc
06 Feb 2011 19:41
#429081
Id really like to see what you cam up with for jeting/setup, any pointers are great.
  • TerryK
  • TerryK's Avatar
06 Feb 2011 19:48
#429083
I have all the specs somewhere nearby because I sent them to another KRZ member last year. I'll dig them up for you asap. What bike/engine combo are you running?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • notaduc
07 Feb 2011 14:32
#429228
1980 kz1000.
  • TerryK
  • TerryK's Avatar
07 Feb 2011 17:30
#429267
Pipe, cams, porting, pistons etc?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
