- Thank you received: 15
tensile strength needed?
- larrycavan
- Visitor
Just some info I found:
Drag Racing Chain Applications By Horsepower
up to 250hp 530DR2 530DRZ2
up to 500hp 630MS
more than 500hp 630SHB 630SHBZ
www.ekchain.com/drag.htm
SRX Series: Value-Priced Quadra-X Ring Chains
SRX-series chains offer excellent value, and improve on the SRO-series chains with the superior sealing and reduced friction of EK Quadra-X Ring seals.
Recommended application: up to 650cc/80hp for 520SRXL; up to 750cc/90hp for 520SRX; up to 900cc/110hp fo 525SRX; up to 1000cc/120hp for 530SRX
Available colors: gold
Tensile strength: 8000 lbs. for 520SRXL; 8500 lbs. for 520SRX; 8800 lbs. for 525SRX; 9200 lbs. for 530SRX
www.ekchain.com/street.htm
And I found a whole bunch of posts on various forums of people arguing about which chain to use. Seems like a popular pastime :laugh:
Get out... I don't believe it :laugh:
- 893cv
If you are talking about chains, you are talking about sprockets too. A used set of sprockets + a new chain = very short chain life. Also, a used chain + a new sprocket = very short sprocket life.
If your going to sell your bike in a few weeks (or miles), sure anything goes. If your going to try to keep your bike long enough to ware out a chain and set of sprockets like I do, I've found its always cheeper to replace these parts as a compleat set.
Stu Pidasole wrote:
most crotch rockets come with aluminum rear sprockets. if my aluminum $40 sprocket goes ill buy one of these first... www.sidewindersprockets.com/
also, this thread was aimed at chains....i see a 530 116 link thats 8,200 t.s. i may just use that for now....not sure.[/quote]
1980 kz1000 LTD
1978 Z1R
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
[/quote]my sprockets and chain are brand new. i allready ordered my chain. thanks though. if needed down the road ill buy a steel or titanium rear sprocket.No, I've never seen a new sportbike with an OEM aluminum rear sprocket. Lots of folks run aftermarket aluminum rear sprockets on the street, but not me.
