tensile strength needed?
  • Stu Pidasole
  • Topic Author
  • if you aint mod'n, you aint rock'n!
03 Feb 2011 15:12 #428198 by Stu Pidasole
tensile strength needed? was created by Stu Pidasole
how many lbs do i need for my 530 chain? going on a 1075, stock cams.
03 Feb 2011 15:15 #428200 by T_Dub
Replied by T_Dub on topic tensile strength needed?
Just get any modern o or x ring chain. They'll be fine.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • Stu Pidasole
  • Topic Author
03 Feb 2011 15:25 #428202 by Stu Pidasole
Replied by Stu Pidasole on topic tensile strength needed?
they all have different tensile strength's.
03 Feb 2011 15:31 - 05 Feb 2011 15:56 #428205 by PLUMMEN
Replied by PLUMMEN on topic tensile strength needed?
get a big one! B)
ive found tensile strength to be a good quality in a chain! :laugh:
Last edit: 05 Feb 2011 15:56 by PLUMMEN.
03 Feb 2011 15:31 #428206 by Lennymon
Replied by Lennymon on topic tensile strength needed?
I snaped a o ring chain with my 1015 (630). As long as you dont do hole shots your ok but i went with a 350HP (630)non o-ring chain Lenny.....
03 Feb 2011 19:32 #428277 by steell
Replied by steell on topic tensile strength needed?
Just some info I found:
Drag Racing Chain Applications By Horsepower
up to 250hp 530DR2 530DRZ2
up to 500hp 630MS
more than 500hp 630SHB 630SHBZ
www.ekchain.com/drag.htm
SRX Series: Value-Priced Quadra-X Ring Chains
SRX-series chains offer excellent value, and improve on the SRO-series chains with the superior sealing and reduced friction of EK Quadra-X Ring seals.
Recommended application: up to 650cc/80hp for 520SRXL; up to 750cc/90hp for 520SRX; up to 900cc/110hp fo 525SRX; up to 1000cc/120hp for 530SRX
Available colors: gold
Tensile strength: 8000 lbs. for 520SRXL; 8500 lbs. for 520SRX; 8800 lbs. for 525SRX; 9200 lbs. for 530SRX
www.ekchain.com/street.htm
And I found a whole bunch of posts on various forums of people arguing about which chain to use. Seems like a popular pastime :laugh:
  • Stu Pidasole
  • Topic Author
03 Feb 2011 19:52 #428280 by Stu Pidasole
up to 500hp 630MS
yeah i had seen that site. was looking at the 530 zzz 1100 tensile. $200.
03 Feb 2011 20:00 #428281 by 893cv
Replied by 893cv on topic tensile strength needed?
I've had very good luck using the DID 530ZLS on my FJ1200. It lists as having 10,520 lbs T.S. The last one did over 20k miles on the street. I also always use steel Sunstar sprockets. Yes, they do cost a bit more then the lesser chains and sprockets, but my bikes are worth it.
1980 kz1000 LTD
1978 Z1R
  • Stu Pidasole
  • Topic Author
03 Feb 2011 20:25 #428285 by Stu Pidasole
gotchya, my rear is aluminum, but my front is steel. will that matter?
  • lemo32
  • The Price of Cool aint cheap
03 Feb 2011 21:11 #428288 by lemo32
Replied by lemo32 on topic tensile strength needed?
Wid dat big ole tire it might be better to leave you a weakest link, better to snap a chain than a tranny or crank :laugh:
1979 kz 1000 06 katana 750
03 Feb 2011 22:04 #428291 by 893cv
Aluminum rear sprockets dont last like steel sprockets. If its a race bike sure, go ahead. If its a street bike, not so much.
This may be the ultimate rear sprocket!
www.supersproxusa.com/index.php
1980 kz1000 LTD
1978 Z1R
04 Feb 2011 01:15 - 04 Feb 2011 01:16 #428303 by nads.com
Replied by nads.com on topic tensile strength needed?
I douby that chain snapped from load
You did something!!
member the old days of not getting stuff right?
bet you do
:woohoo: :woohoo: :woohoo:
Last edit: 04 Feb 2011 01:16 by nads.com.
