- Thank you received: 1
tensile strength needed?
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Stu Pidasole
they all have different tensile strength's.Just get any modern o or x ring chain. They'll be fine.
- PLUMMEN
- Thank you received: 104
ive found tensile strength to be a good quality in a chain! :laugh:
- Lennymon
- Lennymon
- steell
Drag Racing Chain Applications By Horsepower
up to 250hp 530DR2 530DRZ2
up to 500hp 630MS
more than 500hp 630SHB 630SHBZ
www.ekchain.com/drag.htm
SRX Series: Value-Priced Quadra-X Ring Chains
SRX-series chains offer excellent value, and improve on the SRO-series chains with the superior sealing and reduced friction of EK Quadra-X Ring seals.
Recommended application: up to 650cc/80hp for 520SRXL; up to 750cc/90hp for 520SRX; up to 900cc/110hp fo 525SRX; up to 1000cc/120hp for 530SRX
Available colors: gold
Tensile strength: 8000 lbs. for 520SRXL; 8500 lbs. for 520SRX; 8800 lbs. for 525SRX; 9200 lbs. for 530SRX
www.ekchain.com/street.htm
And I found a whole bunch of posts on various forums of people arguing about which chain to use. Seems like a popular pastime :laugh:
- Stu Pidasole
yeah i had seen that site. was looking at the 530 zzz 1100 tensile. $200.Just some info I found:
up to 500hp 630MS
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- Stu Pidasole
gotchya, my rear is aluminum, but my front is steel. will that matter?I've had very good luck using the DID 530ZLS on my FJ1200. It lists as having 10,520 lbs T.S. The last one did over 20k miles on the street. I also always use steel Sunstar sprockets. Yes, they do cost a bit more then the lesser chains and sprockets, but my bikes are worth it.
- lemo32
- The Price of Cool aint cheap
1979 kz 1000 06 katana 750
- 893cv
This may be the ultimate rear sprocket!
www.supersproxusa.com/index.php
1980 kz1000 LTD
1978 Z1R
- nads.com
- Thank you received: 20
I snaped a o ring chain with my 1015 (630). As long as you dont do hole shots your ok but i went with a 350HP (630)non o-ring chain Lenny.....
I douby that chain snapped from load
You did something!!
member the old days of not getting stuff right?
bet you do
:woohoo: :woohoo: :woohoo:
