Cleaning engine fins and cases.
- Maxwedge
- securitygeek
- ltdrider
- Thank you received: 17
I've experimented with different stuff, and I think a scotchbrite pad dipped in Mothers Aluminum Polish works great.
You can fold the pad so it fits between the fins, and it gets in the nooks & crannies. You have to buff the mothers off with a clean cloth, and I use a wooden dowel to force the rag between the fins. It takes time, but with some beer, a stool, and a sunny day, it's not bad duty.
Post edited by: ltdrider, at: 2006/04/25 12:39
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
- KzJim
Also I'm not a big fan of painting air cooled motors, tends to make them run hotter in my experience.
I have been doing some research on heat dispersion calculations.. and ran across this statment in a tech document...
"Unless the component is facing a hotter surface nearby, it is imperative to have the heat sink surfaces painted or anodized to enhance radiation."
I'm gonna look into this a bit more.. i find it interesting..
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- Maxwedge
"Unless the component is facing a hotter surface nearby, it is imperative to have the heat sink surfaces painted or anodized to enhance radiation."..
Hmmm...interesting... I know my FJ1200 seemed to run hotter after I painted the motor. But it may very well depend on the type of paint used too, that paint was pretty thick.
Thank's for the Mothers & Scotchbrite tip. Never tried that one before.
- wireman
- Visitor
- kx_125_pilot
The fins and engine case are cast aluminum, so they'll never shine like chrome, but you can brighten them up alot.
I thought the cases were magnesium
- KzJim
Being the curious fellow i am.. i took apart all 3 PC's in the house.. sure 'nuf... all 3 heat sinks' on the processors are 'painted' black. (i'll use the word 'paint' because i dont know just what the finish exactly is).
There has to be a better answer.. I'm gonna find it...
- wireman
- Visitor
- wireman
- Visitor
ive seen a lot of older dirtbikes with magnesium cases,but 900-1000 cases have always been aluminum as far as i know.ltdrider wrote:
- KL250
I'm not sure about painted surfaces though. I do know that the motor in my bike is painted with alumiblast from the eastwood corp., and the cleared with ppg graphiti resistant clear. It looks awesome, but it sure don't radiate heat very well. It also yellowed really bad in some spots on the head. It sure does clean up easy though, oil wipes right off, where it would just stain bare cast.
- rammy
according to what ive always been told by higher ups flat black is the ultimate for heat disipation. but i still prefer the look of clean aluminum myself. :whistle:
I agree I like the EL NATURAL look my self better might be a little more work in the beginning but once cleaned to your preferance any and all clean up is easyly done.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
