Cleaning engine fins and cases.
- pidaster
Re: Cleaning engine fins and cases.
26 Apr 2006 06:16
For cleaning the fins what about Eagle One mag wheel cleaner? I've never tried it but it's tough stuff. Should clean it very well.
- oldcoldankles
26 Apr 2006 06:30
There's quite a lot of useful info in the archives about this, and over a year ago ltdrider posted a thread about an eraser like cleaning tool which reaches right in to the tight spots between the fins for cleaning them out. I haven't tried it but it seemed like a great idea.
kzrider.com/forum/viewthread.php?tid=20351
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- gas
26 Apr 2006 09:46
I have Dupli color high heat ceramic on a lot of my engine surfaces. It is well cured after a season of riding. When cleaning between the fins this spring I was using Castrol degreaser, the kind in the lever/hand pump dispenser. It was eating off the paint. I finnished off with Gunk engine degreaser and didn't experience the same issue. However, I didn't let the Gunk sit on there very long and cleaned it off with a wet rag. It states that the Gunk can streak paint if left on too long also.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
26 Apr 2006 12:02Post edited by: KZ_Rage, at: 2006/05/16 11:53
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- kx_125_pilot
26 Apr 2006 13:02
wireman wrote:
ah, I stand corrected:lol:
kx_125_pilot wrote:ive seen a lot of older dirtbikes with magnesium cases,but 900-1000 cases have always been aluminum as far as i know.ltdrider wrote:The fins and engine case are cast aluminum, so they'll never shine like chrome, but you can brighten them up alot.
I thought the cases were magnesium
- MattBlack
26 Apr 2006 13:14
KZ_Rage wrote:
Yeah I have a friend who just finishing polishing the frame on his 'Busa. It's pretty close to the chrome parts he has on it I'll say that. Lot's of wet sanding with staged grits then a final hit with a polishing wheel and some compounds. I plan on doing the same to my 650 aluminum parts when I get the bike road worthy.
You can get real close to chrome finish with buffer wheels and compounds. I will take some shots of the cast aluminum stator side cover that I'm polishing on the wifes Honda Rebel. It looks as near to chrome as you can get with aluminum.
I had to "fix" some gouges in the surface from when the bike was dropped. So I'll show you the before and after shots.
- ltdrider
26 Apr 2006 16:12
Can an engine be "too shiney"?
I like a clean engine, I'll admit, but that's because clean runs cooler (that's my story, I'm sticking to it). My aim was to get it looking like it looked when it was new. Once it's clean, it's pretty easy to keep it that way. Polished aluminum is harder to keep up with... it oxidizes pretty fast.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- pidaster
26 Apr 2006 16:54
Where the fins are, wouldn't it be better if it is not polished smooth? The idea is to dissapate heat. An extremely smooth surface does not dissapate as well as a slightly course one.
- kx_125_pilot
26 Apr 2006 22:07Please Log in or Create an account to join the conversation.
- kx_125_pilot
- pidaster
- Nevco48
27 Apr 2006 06:19
kx_125_pilot wrote:
KX- that is an incredible shine you've got there. I can even see a reflection of your feet. Any guess as to how many hours you have spent on the bike? You should post a photo of the whole bike too. I would be afraid to ride that around here unless I had vaccumed the road first!
