Can you flush a motor?
- Sweet Back
- KitNYC
- Thank you received: 1
Sorry, man, couldn't resist! I'm probably one of the least-qualified people on here to answer your question, plus I just finished beer #3 on top of a fever, but... If it was me, I'd probably flush it out with WD40, followed by a second flushing with 10W40, then fill it with 10W40 & change after 50 miles or so. Of course, I would only do that after asking here whether that was a stupid plan or not...
Good luck,
-Kit
- Sweet Back
I knew that was coming, and I'm glad its the first one and out of the way.
- roy-b-boy-b
- Thank you received: 103
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
Post edited by: KZ_Rage, at: 2006/05/16 11:48
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- newbikekiller
I'm SURE someone will be able to tell you exactly what that shiz is called, its at every gas station around here so worst case scenerio I'll just check it the next time I go around for the name.
Peter
- OKC_Kent
- Thank you received: 20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- OKC_Kent
Post edited by: OKC_Kent, at: 2006/04/24 14:42
Oklahoma City, OK
- kx_125_pilot
- rodneyo
- wireman
- Visitor
yep,you might suddenly develop a bunch of strange new leaks and noises.If I were you I would put some fresh oil in and run it a couple hundred miles and change your oil again.And leave it at that.Alot of times flushing with solvents and things like that you do more harm than good.
- kx_125_pilot
