Can you flush a motor? 23 Apr 2006 23:52 #42053
  • Sweet Back
  • Sweet Back's Avatar Topic Author
  • Thank you received: 0
I just purchased a crashed cop bike. It's been sitting for about 9 years. Its my intention to put this motor in my current bike after putting on new gaskets. Is there a way I can flush the motor? I'm concerned about what I might use because I think it will effect the clutch. I don't really know, just looking for a product that I can get rid of what I believe will be some sludge. Any other tips are appreciated.
1996 KZ1000P
Can you flush a motor? 24 Apr 2006 00:14 #42056
  • KitNYC
  • KitNYC's Avatar
  • Thank you received: 1
Well, AFAIK, US police bikes are liter engines, & most US toilets are at least 3 liters per flush. You'd think that would mean the cop bike motor would fit with room to spare, but it won't!!!! DAMHIK! :ohmy: :laugh: :P ;)
Sorry, man, couldn't resist! I'm probably one of the least-qualified people on here to answer your question, plus I just finished beer #3 on top of a fever, but... If it was me, I'd probably flush it out with WD40, followed by a second flushing with 10W40, then fill it with 10W40 & change after 50 miles or so. Of course, I would only do that after asking here whether that was a stupid plan or not...
Good luck,
-Kit
Can you flush a motor? 24 Apr 2006 00:27 #42058
  • Sweet Back
LMAO!
I knew that was coming, and I'm glad its the first one and out of the way.
1996 KZ1000P
Can you flush a motor? 24 Apr 2006 02:19 #42066
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
  • Thank you received: 103
I removed the oil pan from the "77" LTD i bought and it was clean as compared to some engines i've seen. If you flush your engine the crud will still be in the pan. Got a extra oil pan gasket? Roy
Can you flush a motor? 24 Apr 2006 05:52 #42090
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
  • Thank you received: 19
Post edited by: KZ_Rage, at: 2006/05/16 11:48
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Can you flush a motor? 24 Apr 2006 09:58 #42159
  • newbikekiller
  • newbikekiller's Avatar
Well, I've never done it personally but there are a lot of folks around here who use a certain fuel system/carb/fuel stabilizer I forget what kind but it comes in a white can with red lettering in their oil for 50 miles or so as an engine flush. Supposed to work pretty good. You can run it in your gas too to clean that out a bit.
I'm SURE someone will be able to tell you exactly what that shiz is called, its at every gas station around here so worst case scenerio I'll just check it the next time I go around for the name.
Peter
Can you flush a motor? 24 Apr 2006 10:21 #42165
  • OKC_Kent
  • OKC_Kent's Avatar
  • Thank you received: 20
Stabil
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Can you flush a motor? 24 Apr 2006 10:22 #42166
  • OKC_Kent
  • OKC_Kent's Avatar
Dam, double post, and I meant to say "Seafoam" . What's with the double post that always happens to me??
Post edited by: OKC_Kent, at: 2006/04/24 14:42
Oklahoma City, OK
Can you flush a motor? 24 Apr 2006 10:23 #42168
  • kx_125_pilot
  • kx_125_pilot's Avatar
ive heard of people using transmission aditives because they are high detergent and apperently it works pretty good
Can you flush a motor? 24 Apr 2006 11:40 #42196
  • rodneyo
  • rodneyo's Avatar
If I were you I would put some fresh oil in and run it a couple hundred miles and change your oil again.And leave it at that.Alot of times flushing with solvents and things like that you do more harm than good.
Can you flush a motor? 24 Apr 2006 12:08 #42210
  • wireman
  • wireman's Avatar
  • Visitor
yep,you might suddenly develop a bunch of strange new leaks and noises.;)
Can you flush a motor? 24 Apr 2006 17:01 #42297
  • kx_125_pilot
thats why detergent additives are a better way to go, because there ment for what your trying to do
