- Thank you received: 1
Quick release spark plug...
- Becker
- The Doctor Will Rise Again
you will need to drill and tap the hole to use the helicoil or the timesert, so you will get chips in the cylinder you will need to get out.
I was thinking about this too. Is there any way to do this while the head is still on the motor?? I was thinking of something like turning the motor to TDC when both valves are open and hooking a shop vac to the exhaust side with the header and carbs off. Think that would work?? I don't need to do this but just for future reference.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- cyclhed
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- mtbspeedfreak
- Thank you received: 36
Thanks!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- Kidkawie
- I bleed premix
- Thank you received: 245
:laugh:
Used these on one of my cars about 100k miles ago, Napa carries them: www.acehardwareoutlet.com/productdetails...80&source=GoogleBase
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Thank you received: 2098
The inaugural use of my new torque wrenches will be to torque down new sparkplugs. What's the torque spec for these? '76 KZ900 if it matters. Thanks!
Hoping they're the genuine "Black Forest" brand.
18.5~22.0 ft-lbs
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Works quite well.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- mtbspeedfreak
18.5~22.0 ft-lbs
Of course, AND I used elbow grease to lube the threads. I figured real grease would "carbonize" and make a mess of things.
2000 ZRX 1100
