Quick release spark plug...
- MAYHEM
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- trianglelaguna
- Thank you received: 235
Tims right....
they make a cheaper solution but it is get what you pay for...you need a thread repair kit (heli coil kit)for that size spark plug
this i a clip i googled but it shows the basic idea
www.popularmechanics.com/cars/how-to/repair/4212608
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- timebomb33
- Thank you received: 2829
- MAYHEM
I've used helicoils before, just didn't know you could use them for spark plugs (or any other high compression application).
A buddy of mine has a head off of a KZ650, I was thinking of using that...but I'll give the timeserts a try.
Thanks a bunch!
- hocbj23
- Visitor
- trianglelaguna
but theyt never messed up and are around 20 for the kit as oppossed to 75-100 for timserts...
But...Tim (timebomb)is a true mechanic so i said nothing...i do think they are good enough for a stock comp motor....
1976 KZ900
2003 ZX12R
2007 FZ1000
- testarossa
- Thank you received: 82
if you are going to do it don't be tempted to use helicoils like they say in that write up they will come out and also they don't deal well with high cylinder head temps and high compression pressures. pay a few bucks more and use the timeserts or equivilent you'll be happy you did.
I'm being completely sincere when I ask this question. Not ballbusting and not knocking timeserts. Do you have any personal experience with a heli-coil actually coming out? I have been fortunate in that I have never had to use one for a spark plug, so I claim no experience. I don't understand why a helicoil would not deal with heat. Standard helicoils are steel, and the aluminum heads are good enough to deal with combustion temps. I do realize that galvanic corrosion can occur between the steel and aluminum. Is this the issue? Would the timeserts not have the same issue?
Do the plugs not seal against the top surface of the head? I have heard the recommendation to use timeserts before, but no real explanation of what makes the helicoils unusable.
I have personally machined many aluminum parts for NASA that require the installation of helicoils per MILSPEC. Granted, these parts were not part of an internal combustion engine, but you can believe me that NASA flight parts are very closely examined. They would not specify helicoils by accident. By the same token, you can also believe that if I had substituted a timesert in place of a helicoil, that the part would be rejected due to the fact that the threaded insert did not carry the proper certification. One thing that the military does specify the use of Super Koropon primer for all threaded insert installation. I believe that this primer mitigates any chance of galvanic corrosion.
Sorry for the lengthy post, but I honestly am ignorant of the problems associated with the use of helicoils to repair stripped spark plug threads. I am hoping that you have had some personal experience with the failings of a helicoil in this application. I'm sure that the timesert is actually a stronger option to a helicoil and if a helicoil would work, then a timesert certainly would as well.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
I have used both over the years. Heli-coils will come out, good for a quick fix however. As Tim said the timeserts, are a longer term fix. One is colied threads and the other is a sleeve. Yes a timesert kit costs more, it is about the same price as having the shop, fix one cylinder. There is a reason, one costs more then the other..........Both will work for ya!
- testarossa
Certain applications for NASA do require an insert similar to a timesert. I have actually used these. Threaded, key locked, inserts: www.carrlane.com/Catalog/index.cfm/27825...070F1A3C3B285356445C
I'm specifically interested in someone who has had actual evidence of a helicoil unscrewing itself. Not anecdotal evidence.
2004 ZX-10R
Angola, IN
- cyclhed
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
