- Thank you received: 18
Engine Knock
- larrycavan
- Visitor
Pull it, take it apart, clean it, sand the plungers with some 1000G paper to debur them.
The springs also sack out over time. APE has an aftermarket manual adjust unit that cures the problem once and for all.
Larry C
- Kawickrice
As was said above get a mechanics stethoscope and you should be able to determine the source of the noise. Good Luck
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- grumpy56
- Thank you received: 6
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- Motor Head
- Thank you received: 391
Have you done a carb sync while engine is at temp and running? If the offending piston is getting a stronger signal than the others it may amplify the noise.
New springs for the cam chain tensioner are available from Kawasaki, around $18 for the 2. There is also a O-ring here where the tensioner bolts up. Remember to turn the motor to TDC 1/4 mark before removing tensioner.You can do this at the same time you look for your oil leak at the cooler hoses etc.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- trianglelaguna
- Thank you received: 235
I'll go with the piston slap as you're noise.
maybe this above fuel/carb idea makes the most sense to an idiot like me.....i would think a rod or bearing or piston slap would act up at stop signs and creeping along in traffic...or leaving a dead stop when warm...i would think a cam chain/tensioner would act up when you close the throttle and start gearing down /clutch in-coming to stop lights (or while idling in neutral after warm,,,does it pop or stumble when warming up a bit from overnight off...what do the plugs look like....almost sounds like a fuel starve on a cylinder for a flash then clears and carbs correct...
total idiot here but...the sound you describe reminds me of forgetting to turn my gas on while running errands after a stop....as it just starts to stumble it knocks...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
