- Thank you received: 6
Engine Knock
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- BSKZ650
- Thank you received: 14
oil and filter change
77 ltd1000, current rider
76 kz900, just waiting
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- bountyhunter
- Thank you received: 337
If it was a 'clacking" sound it might be the primary chain slapping around.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- steell
Rod bearings can cause a knock, as can main bearings and pistons, and wrist pins, and a few other bearings. But bearings that knock don't get any better when the motor gets warmed up. Piston slap (sounds like a knock) can go away when the motor warms up.
I think the J motors were notorious for piston slap, APE Jay told me one time that he made a significant sum of money installing 1075 kits in J police bikes because of cylinder wear (causes piston slap).
Kind of hard to diagnose over the interweb though, so it might be something else causing it
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- bountyhunter
No, I meant the primary chain because I didn't know they made one without it.:laugh:Appreciate the info guys. I think bountyhunter may have been referring to the cam chain (rather than primary). My scoot has made this racket for the 2 years that I've had it and it doesn't appear to have gotten any worse. If I recall from my younger days, and my younger days are way way too long ago to remember, piston slap had a sort of ringy/hollow sound to it (if that description makes any sense). But then, could have been caused by the hollowness between my ears. Who knows.
If it's a clacky sound, it might be a cam chain. have you checked the chain tensioner assembly?
Don't tell me it doesn't have one of those either......:blink:
- Thank you received: 2098
Need some expert opinions/advice. When I first start my J, it sounds fine. Normal ticking valves and such. fine for about 15 seconds. Then, it develops a noticeable knock. Can't tell where it is coming from, but does not sound good. After about 30 seconds, it completely disappears and I don't hear it again until the bike sits overnight. The ritual described is consistent and it has been doing this for about a year (granted I've only put about 1000 miles on it in that time). Ay thoughts? Thanks.
Another theory --
Clogged oil pump screen or oil journal.
Residual oil from last run lubes for 15 seconds.
Then knocks for 30 seconds until oil arrives.
Could use stethoscope to help locate knock source.
And as already suggested, use oil gauge to determine pressure at start-up and extent of any delay in building pressure.
But am uncertain whether that could cause the symptoms as described.
Wouldn't hurt to check integrity of the filter.
And could also test run for effect without the filter.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- steell
Nope, bevel gear drive!!
Just kidding :laugh:
