GPZ750/810 racer running....
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: GPZ750/810 racer running....
17 Mar 2011 08:59
#438574
turboguzzi wrote:
yep, thats one solution, Yoshi used to do that, Schwantz's early 750 GSX's and GSXR's had that kind of carb heat shielding.
My plan is to go beyond that and build an actual airbox so that carbs not only suck non-heated air but also air that is still and non-turbulent.
Get the airbox and runner volume right and you can even get a boost from that too. Open carbs are very old school today....motogp and WSBK run airboxes.
I am just at the beginning of the development process for my racer, have plenty of plans and areas for improvement, hei! havent even ported the head yet :)
just taking some time off being in the garage every night. will pick up development again in the two month break i have mid season.
I hear you on the development. I progressed my bike almost every race weekend last year, and that was 5 rounds changing carbs, jetting, and big bore. 4 dyno runs as well. You have done a lot to that machine, so leaving things as they are, and concentrating on actual racing, is another thing.
Making a breathable airbox protected from heat will still let the engine breathe.
Are you running an oil temp gauge on that beast? If so, what temps are you getting?
'85 GPz550(ZX550-A2)
  • turboguzzi
  • turboguzzi's Avatar Topic Author
17 Mar 2011 09:44
#438581
nope, not measuring temp, not worried about it either.
if i'll start hearing the motor pinging I'll know it's getting too hot :) its definitely not.
build a good working squish area that gives quick burning = less time to heat up the combustion chamber = motor runs cooler
I'm down to only 28 degs full advance right now and the torque peak is still a very healthy 58 lb/ft, as good as a current GSXR750 with four valves and water cooling (just at lower revs, dang!) Stock GPZ750 was 41 lb/ft just to give you an idea, so you can get good torque with late timing too if you have the right turbulence inducing squish in there
TG
  • larrycavan
  • larrycavan's Avatar
19 Mar 2011 09:46
#438902
On an air cooled bike, those heat barriers are IMO, not effective to any great extent. They could even be detrimental.
They're going to block air between the cylinders and trap more heat in motor anyway. That trapped heat will transfer to the intake ports...etc.
A correctly sized airbox would be more effective to feed the engine cooler air.
If a shielding device were to be attempted, it might best be designed to shield the float bowls front and bottom. The idea being to allow air through the block between the cylinders and guide it underneath the carburetors.... JMO
An air box that completely enclosed the carburetors would be worth the attempt...again JMO.
Larry C
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
19 Mar 2011 14:59
#438956
how much piston to head squish clearance are u running? i ran my 1327cc kz motor at .036" and had no problems.
turboguzzi wrote: nope, not measuring temp, not worried about it either.
TG
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • turboguzzi
20 Mar 2011 16:17
#439195
mark1122 wrote: how much piston to head squish clearance are u running? i ran my 1327cc kz motor at .036" and had no problems.
.030"
  • turboguzzi
20 Mar 2011 16:20
#439197
larrycavan wrote: On an air cooled bike, those heat barriers are IMO, not effective to any great extent. They could even be detrimental.
Larry C
with you on this larry, an airbox rather than open barrier is my plan indeed.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
21 Mar 2011 15:48
#439440
Larry C
this pic shows the under the float bowl deal.
  • CoreyClough
  • GPz550 Addiction
21 Mar 2011 16:05
#439442
Dang that is a sweet looking bike. Nice belly pan too.
Dutch, you looking at this???
  • 531blackbanshee
  • Vendor
  • Vendor
21 Mar 2011 16:21
#439445
haha come on sander,make us some belly pans!
i have been searching for a belly pan.
it could be the only un-needed piece that a street bike could have that i want. :whistle:
i guess it is the wannabe racer boy in me :evil: ,haha.
  • trianglelaguna
  • trianglelaguna's Avatar
21 Mar 2011 16:36
#439450
anyone ever seen a link to pans???
great pics guzzi!!!!
wannabe racer boy....here we go again banshee.:kiss:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • 531blackbanshee
  • Vendor
  • Vendor
21 Mar 2011 17:01
#439459
trianglelaguna wrote: anyone ever seen a link to pans???
it's me and you tri!
till the bed collapses,or the wheels go square :laugh: .
  • T_Dub
  • T_Dub's Avatar
21 Mar 2011 17:18
#439464
Oh I really want a belly pan for when I do my turbo build. I think my 650 doesn't need one.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
