Clearancing Head for Cams - Photo?
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
05 Nov 2010 18:14 #411052 by kzz1p
Replied by kzz1p on topic Clearancing Head for Cams - Photo?
keith1 wrote:
kzz1p wrote:
:woohoo:
exactly.....B)......mine has better machine work though....:P
Mine has the photoshop clone tool.
05 Nov 2010 18:22 #411056 by keith1
Replied by keith1 on topic Clearancing Head for Cams - Photo?
kzz1p wrote:
keith1 wrote:
kzz1p wrote:
:woohoo:
that would explain a few things......B)
  • testarossa
05 Nov 2010 18:59 #411064 by testarossa
Replied by testarossa on topic Clearancing Head for Cams - Photo?
Excellent info. Thank you gentlemen. I can use this in the future.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • DoubleDub
  • Topic Author
  • Visitor
05 Nov 2010 21:04 #411110 by DoubleDub
Replied by DoubleDub on topic Clearancing Head for Cams - Photo?
Patton wrote:
So does the red box area above the bucket need to be clearanced also for a .410 or smaller cam? Or just the areas at the edge around the gasket? I guess that's where I'm not clear. And will a .410 fit without any clearance other than the valve cover as suggested? I was under the impression about .385 was the max without some clearancing on my Kz900 and the Kz1000's.
  • kzz1p
05 Nov 2010 21:20 #411118 by kzz1p
DoubleDub wrote:
The red box on both side of the cam lobe, is the area to clearance for .410" and above.
05 Nov 2010 23:37 #411127 by kawsakiman
Replied by kawsakiman on topic Clearancing Head for Cams - Photo?
kzz1p wrote:
yes and a little in the bucket area.
06 Nov 2010 05:58 #411153 by Old Man Rock
Replied by Old Man Rock on topic Clearancing Head for Cams - Photo?
Valve cover grinding is one thing but the head deck and around the buckets.... Scary thought....
Issues with shim spitting out in this concept or do you go under bucket shims?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • DoubleDub
  • Topic Author
  • Visitor
06 Nov 2010 06:04 #411156 by DoubleDub
This was the area I really wanted to see a picture of as it seems scary to me also.
APE says top-ships are okay, but Webcam says under-bucket should be used on their .418 .... ??? Not sure.
06 Nov 2010 06:08 #411160 by Old Man Rock
Since the shim buckets rotate in the head, seems to me you'd have to go 360 around in grinding blue box area and have to go under bucket....
Just thinking out loud here... probably wrong... :S
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • DoubleDub
  • Topic Author
  • Visitor
06 Nov 2010 06:24 #411163 by DoubleDub
I'm surprised nobody has a photo of a head that has been prepared for bigger cams....wtf people!
  • larrycavan
  • Visitor
06 Nov 2010 06:31 #411166 by larrycavan
Replied by larrycavan on topic Clearancing Head for Cams - Photo?
What cam are you putting in the bike?
  • DoubleDub
  • Topic Author
  • Visitor
06 Nov 2010 06:33 - 06 Nov 2010 06:34 #411167 by DoubleDub
I haven't decided yet, and was more just curious about what had to be done. Likely it will end up being the Webcam 118 which is supposed to be a drop-in.
In all seriousness, I was just curious what the machining by the bucket involved as that was the region I assumed the lumpy cams needed worked on.
Last edit: 06 Nov 2010 06:34 by DoubleDub.
