Clearancing Head for Cams - Photo?
- DoubleDub
05 Nov 2010 12:37
Does anyone have a photo that shows what the areas need to be clearanced for higher lift cams?
I'm considering getting a set this winter for my Kz and was just curious. I'll likely end up with a drop-in set, but I'm curious where and how much material typically needs to get removed and since I don't have a set of non-drop-in cams I'm having a tough time visualizing what needs to be done (although I think I have an idea?).
Thanks in advance!
Thanks in advance!
- testarossa
Re: Clearancing Head for Cams - Photo?
05 Nov 2010 13:04
DoubleDub wrote:
X2 Plummen said he was going to do just this thing, but I somehow missed the post.
Thanks in advance!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Injected
05 Nov 2010 13:05
Which KZ?
For my 650 the cover is high so unless your running over .400" then it does not have to be ground... I think the 900 might have some "X"'s cast in the cover to deal with.
As for the head, the area is the cam lobe pathway from the insides of where the bucket rides up and down to the gasket surface on both sides of the bucket hole... usually have to take roughly 1/8" out of there - it depends how big the cams are... you can't take so much as to ruin the gasket surface.
Don't have a photo to show you... think I explained it good enough.
1978 KZ650B2 modified project
05 Nov 2010 14:58 - 05 Nov 2010 15:03
Inside surface of stock valve cover (see image) may need relieving (by grinding down the X marks) to prevent contact by cam lobe.
Last edit: 05 Nov 2010 15:03 by Patton.
- DoubleDub
05 Nov 2010 15:25
Injected wrote:
Thanks, that helps, but I'd love to see a clearanced head to compare to my stock head.
I think the 900/1000 heads were similar with a lift over .400 requiring clearancing, although I remember Larry preaching that you should never assume and always double check with aftermarket cams .... :silly:
Patton - you wouldn't happen to have a picture of a clearanced head near the buckets would you?
Which KZ?
05 Nov 2010 15:53
DoubleDub wrote:
Sorry, no pic of clearanced head near the buckets.
Am also learning from this thread.
Guessing the described relief would be from the area indicated in red on this pic (both sides of bucket tower, but one side hidden by lobe in this pic).
[Click on image to enlarge view.]
Injected wrote:Thanks, that helps, but I'd love to see a clearanced head to compare to my stock head....KZ...900 might have some "X"'s cast in the cover to deal with.
...happen to have a picture of a clearanced head near the buckets....
05 Nov 2010 16:00
On second thought, may be referencing the area shown in blue.
Seems pretty scary to me --- cutting into an already thin gasket mating surface.
- Injected
05 Nov 2010 16:14 - 05 Nov 2010 16:18
That second picture with the red and blue is exactly what I am talking about... my head is currently on the bike and all buttoned up for its winter nap, so no chance of a pic... but yes if you need to thin the gasket flange, it is what it is, cam can't rotate without clearance - no issues so far.
I went almost half way across the gasket flange - only as wide as the lobe, because I am running a massive cam in the 650 head.
So I guess the pics are already up...
Last edit: 05 Nov 2010 16:18 by Injected.
- keith1
05 Nov 2010 17:37
Patton wrote:
you are correct sir on a 900/1000....i have a decent example in the garage i just referenced...i believe it to be good for .410 cams if anyone is interested.....
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- keith1
05 Nov 2010 17:56 - 05 Nov 2010 17:58
Last edit: 05 Nov 2010 17:58 by keith1.
