KZ750 twin exhaust cam for intake for more power?
- dnz
26 Oct 2010 19:48
Will this work to make more power? Would be a cheap source of extra power.
- Becker
- The Doctor Will Rise Again
Re: KZ750 twin exhaust cam for intake for more power?
26 Oct 2010 21:02
I'm sorry I'm not one hundred percent sure what you are talking about. Flip flopping the cams or installing a separate exhaust cam to put in as the intake cam. Why do you think this will help horsepower. I'm just curious.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- bountyhunter
26 Oct 2010 22:06 - 26 Oct 2010 22:09
dnz wrote:
In general, bike engines are tweaked up so fine in matching the intake, cam, exhaust characteristics for maximum power that screwing around with any one will almost certainly make it worse.
You have to change them as a set and you really have to know what you are doing to get it right.
If there was a cheap and/or easy way to jack up the power, kawi would certainly have done it. HP ratings on bikes is a major selling point.Will this work to make more power? Would be a cheap source of extra power.
Last edit: 26 Oct 2010 22:09 by bountyhunter.
- Headly
26 Oct 2010 23:35
Dont know what specs these cams are but i know some jap 4 cylinder bikes have intake cams with more lift/duration than the ex cam,people run 2 intakes in busas,zzrs etc.I dont think there is much gain myself was always told exhaust doesnt have as much effect on producing power in an engine as the intake side of things done,dont know if thats bad advice or what but ex valves always seem to be smaller than intakes maybe fuel in flows more important than waste out?:huh:
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- 893cv
26 Oct 2010 23:46
No, the cam lobes are not in the same location. Different distance from the sprocket to the center of the lobe.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- dnz
27 Oct 2010 09:42
Becker wrote:
I had read that some engines can gain HP by doing this, like the Busa's. I should've said intake not exhaust. The reason is because the intakes valves are larger than exhaust.
- zed1015
27 Oct 2010 10:39
GO FOR IT.
Fitting an inlet cam on the exhaust side is an age old dodge to aid scavenging and get a better cylinder intake fill at higher revs.
Ask anyone with an old triumph bonny etc, This is/was a common tuning mod when over the counter aftermarket cams etc were not available.
Start off with the std lobe centers and work from there.
You'll be very unlucky to get an adverse effect, You should gain 'slightly' more top end power and a willingness for the engine to rev out more cleanly.
A small up jet may be needed and a free flowing air filter would help.
Of course it may make no difference at all depending on how much difference there is between inlet and exhaust cams but you'll never know till you try it
- Nebr_Rex
27 Oct 2010 15:50
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 893cv
27 Oct 2010 17:48
If you install the exhaust cam on the intake side of the head, it will not turn.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- bountyhunter
27 Oct 2010 22:36
893cv wrote:
On mine, the exhaust cam has a tach drive on one end.If you install the exhaust cam on the intake side of the head, it will not turn.
- Becker
28 Oct 2010 00:03
I think he wants to install an intake cam on the exhaust side. On these bikes the IN cam has an extra 20 degrees of duration. It may improve the breathing of the head but to be completely honest I have both the stock 750 twin and a 650 4. The twin will pull up redwood stumps but if you want a screamer just spend the money and get a 650 or even better a 1000. The 750 was a great bike and I absolutely love mine, but its probably the only bike I'll ever just keep stock. It's not worth modifying and I really like it the way it is.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Headly
28 Oct 2010 00:22
Touche"
