  • Page:
  • 1
  • 2
stock carb jetting 25 Oct 2005 06:42 #4059
  • jdevoe
  • jdevoe's Avatar Topic Author
  • Thank you received: 0
does anyone have the stock jetting size for a 77 kz650 c1
stock carb jetting 25 Oct 2005 07:16 #4073
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
There are so many 650 variations of the VM24 I hate to guess but the mains are EITHER #97.5 or #102.5... more likely the latter as the #102.5s were used on quite a few more variations. The pilot jets are #15s and the jet needles are clipped to 4th slot.
stock carb jetting 25 Oct 2005 10:49 #4121
  • jdevoe
Basicly what i am dealing with is i bought the bike and the previous owner put a 4 into 1 with a kerker but never jetted the bike i am in va and looking for someone to do it for me. i just had the carbs dipped and i want to get everything running right.
stock carb jetting 26 Oct 2005 09:27 #4396
  • jdevoe
well no luck been calling around and out of 7 shops not one will work on a "JAP" bike i figured money was money but who knew
stock carb jetting 26 Oct 2005 10:02 #4406
  • jdevoe
anyone have any exspiriance with these dial a jet systems?
www.thunderproducts.com/dial_a_jet.htm
stock carb jetting 26 Oct 2005 10:20 #4415
  • hat0791
  • hat0791's Avatar
interesting concept that's for sure...
stock carb jetting 26 Oct 2005 18:29 #4530
  • Mellvis
  • Mellvis's Avatar
  • Thank you received: 3
If you search the archives you will find a thread that I think wiredgeorge started that several members listed their jetting for different models of KZ's
I ran a 650 with Kerker and pod filters with 110 and 112.5 mains and raised the needle one notch or two notches wit 15 pilot jets.
Good luck!
stock carb jetting 27 Oct 2005 18:44 #4782
  • DanOz7Five0
  • DanOz7Five0's Avatar
Here is that thread. I saved it under favs because I knew it will be helpful to many of us, including me. kzrider.com/forum/viewthread.php?tid=18321
stock carb jetting 31 Oct 2005 06:12 #5557
  • jdevoe
Thanks for the info. one more question. i took my carbs off to clean them and i took pictures of how they were put together and wich ports the fuel lines went to but in a drunken haze i managed to delete the pics. now i have 3 possible spots for the small fuel line off the petcoc. 2 on 1 carb and 1 on another the other 2 carbs dont have ports on the side. i am wondering if anyone has a picture of an assembled unit with the lines attached. Any help would be appreciated.
stock carb jetting 01 Nov 2005 11:24 #5928
  • luvmykaw
  • luvmykaw's Avatar
  • Visitor
Buykawasaki.com has the 1977 KZ 650 C1 listed as having 15 pilots and 102.5 mains. My 1977 KZ650 B1 with Mikuni VM 24 carbs had 15 pilots and 97.5 mains when I opened them up last winter.
I'll try to get a pic of your carbs, for fuel line location.
Post edited by: luvmykaw, at: 2005/11/01 14:35
stock carb jetting 01 Nov 2005 11:32 #5931
  • luvmykaw
  • luvmykaw's Avatar
  • Visitor
stock carb jetting 02 Nov 2005 06:22 #6070
  • jdevoe
do you have the nomenclature that corresponds to the #s on the diagram? thanks for the post also it is what i was looking for
  • Page:
  • 1
  • 2
